Problem with brake light!!
Old Mar 24, 2003 | 02:12 PM
VTEC's Avatar
Question Problem with brake light!!
everytime when i had my car park overnight i will have my brake light on dash with stay on when i start on the car.
And it will stay on until i start driving. Once i press the brake it will come on again.then i let go the brake then it will go off.until my car warn up. I check my brake oil and it stay at MAX mark. i know it won't ba brake pad coz i just change mine to AEM pad at Sept.
Old Mar 24, 2003 | 04:53 PM
FTM-1's Avatar
Post
There might be 2 possible causes. This comes from a person that does not do any work on his car but wash & polish & go to dealer for service. The first cause might be the brake pads because this will happen when pads get low. But you said you have changed them. The second cause could be an (Inop) Master Cylinder Float Level Cap on your brake fluid resivor. I had each problem happen on my 2000TL. The float level cap happen last year when I got my 30K service. They checked everything & the stupid light came back on the next mourning. It would do it first thing in the mourning & stay on about a mile or two. It would then go out & not do it again untill the next mourning when I first started the car. When ACURA fixed the problem I had no problemafter that. I did a few months ago need rear brake pads & that light came back on again. It could be one or the other but that float level cap might be it let me know what it was.
Old Mar 24, 2003 | 05:42 PM
Tom Blasing's Avatar
is the Mighty Favog
This a shot in the dark but you may want to be concerned with the anti-lock brakes. I've heard this can be a warning to such a system.
Old Mar 25, 2003 | 04:31 AM
Hey VTEC where in Weston are you from? My best friend moved out there a few months ago and I'm in love with your neighborhood. He's on Medinah within one of Arvida's communities. I have a goal to live there within 3 - 5 years! Lucky guy!
Noam
Old Mar 25, 2003 | 07:27 PM
Crav4Speed's Avatar
Originally posted by FTM-1
The second cause could be an (Inop) Master Cylinder Float Level Cap on your brake fluid resivor. I had each problem happen on my 2000TL. The float level cap happen last year when I got my 30K service. They checked everything & the stupid light came back on the next mourning. It would do it first thing in the mourning & stay on about a mile or two. It would then go out & not do it again untill the next mourning when I first started the car. When ACURA fixed the problem I had no problem after that.
I had the same problem and that was the cause... they changed it and it never happened again
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
HeloDown
Sep 8, 2015 06:51 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
