Problem with brake light!!
everytime when i had my car park overnight i will have my brake light on dash with stay on when i start on the car.
And it will stay on until i start driving. Once i press the brake it will come on again.then i let go the brake then it will go off.until my car warn up. I check my brake oil and it stay at MAX mark. i know it won't ba brake pad coz i just change mine to AEM pad at Sept.
1 Post
There might be 2 possible causes. This comes from a person that does not do any work on his car but wash & polish & go to dealer for service. The first cause might be the brake pads because this will happen when pads get low. But you said you have changed them. The second cause could be an (Inop) Master Cylinder Float Level Cap on your brake fluid resivor. I had each problem happen on my 2000TL. The float level cap happen last year when I got my 30K service. They checked everything & the stupid light came back on the next mourning. It would do it first thing in the mourning & stay on about a mile or two. It would then go out & not do it again untill the next mourning when I first started the car. When ACURA fixed the problem I had no problemafter that. I did a few months ago need rear brake pads & that light came back on again. It could be one or the other but that float level cap might be it let me know what it was.
Hey VTEC where in Weston are you from? My best friend moved out there a few months ago and I'm in love with your neighborhood. He's on Medinah within one of Arvida's communities. I have a goal to live there within 3 - 5 years! Lucky guy!
Noam
Noam
Originally posted by FTM-1
The second cause could be an (Inop) Master Cylinder Float Level Cap on your brake fluid resivor. I had each problem happen on my 2000TL. The float level cap happen last year when I got my 30K service. They checked everything & the stupid light came back on the next mourning. It would do it first thing in the mourning & stay on about a mile or two. It would then go out & not do it again untill the next mourning when I first started the car. When ACURA fixed the problem I had no problem after that.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
HeloDown
09-08-2015 06:51 PM
