Problem with a 2000 TL
Old Feb 27, 2009 | 05:04 PM
Agentphan007's Avatar
Hi Guys,
As you guys all know I am in need of help. Can anyone chime in, the problem i am having is a wierd noise at low speed stops it sound like metal rubbing while braking. it only comes on while breaking soft when I apply a good amount of pressure on the brakes it does not make the noise. Also my brake pads have plenty life left and i have new rotors and I also gotten both wheel bearings replaced. My second question are the axles suppose to have play when the car is jacked up. both my axle have play in them meaning with the wheels on i can spin them forward and then it stop at about 1in.
Thanks,
Old Feb 27, 2009 | 10:07 PM
Rajca's Avatar
wham bam thank you ma'am
what kind of pads are u using? you will be able to spin the wheels a bit.
Old Feb 27, 2009 | 10:34 PM
bucsteve's Avatar
it could be moister if the sqeeking happens only in the mornings
Old Mar 2, 2009 | 09:44 PM
I don't think its the pad since i've replaced them with both oem and aftermarket oe replacement and still getting the noise. however today i've inspected it and looks like i need two tie rod ball joints
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
