Pressed the gas pedal, car wouldn't accelerate...
Old 05-18-2005, 09:36 PM
USMC Butterbars
shimbo519's Avatar
So I'm driving at 30mph and I go to accelerate, and my car won't move. I floor the car, but it just wouldn't accelerate. I let go of the pedal and tried to accelerate and again nothing. Tried it a third time and finally the car kicked forward and I was on my way. I tried to duplicate it, but nothing. O man, I hope this doesn't mean tranny #3.
Old 05-18-2005, 10:11 PM
Poleshuk S's Avatar
sounds like it..
whats the milage
Old 05-18-2005, 10:33 PM
El Presidente
dark inspire's Avatar
do the revs go up when u floor it? if so and there is no engagement in the gears, then unfortunately its that time...
Old 05-18-2005, 10:41 PM
USMC Butterbars
shimbo519's Avatar
I have about 60k miles. The first tranny went at around 35-40k miles.
Dark Inspire- Strangely enough, the car didn't even rev. It was as if I wasn't even pressing the pedal. Freaked me out considering it was a busy road and the car behind me had to switch lanes to avoid hitting me.
Old 05-19-2005, 05:05 AM
MikePA's Avatar
Check the throttle cable for binding?
Old 05-19-2005, 08:27 AM
Not Asian
phipark's Avatar
sounds like the throttle cable.
Old 05-19-2005, 08:33 AM
VTEC11's Avatar
Are any of the lights on the dashboard on? If the revs didn't go up, it dosn't sound like a tranny problem.
Old 05-19-2005, 10:19 AM
El Presidente
yeah, in that case it sounds like a loose connection, because usually when the tranny is slipping it'll rev but won't go.
Lights on the dashboard dont necessarily indicate whether your tranny is going or not, my last tranny went w/out a single light.
Old 05-19-2005, 10:35 AM
Moderator Alumnus
FiftyFive's Avatar
if it is the transmission then when you hit the gas, the car will rev but wont go anywhere, if it just doesnt rev it could be a throttle cable, and check the car at idle for any abnormalities, could be a misifire but i doubt it
Old 05-19-2005, 03:33 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
like the others said. doesnt sound like a tranny. if it wa the revs should have gone up. sounds like something else?? like a stuck throttle cable??
Old 07-26-2010, 09:32 AM
hamica03's Avatar
I'm having the same problem!
Was it, in fact, the cable throttle?? My car does the same thing. I'll press the gas, and the car doesn't accelerate. The RPMs drop down like I'm just coasting. Downshifting and flooring it doesn't help, then after about 5-7 seconds it'll start to go again. Then if I let off the gas and press again, the same thing happens. I've brought my car to 2 dealers now and they all said they couldn't duplicate it, and therefore couldn't do anything about it. It doesn't do it all the time but when it starts to do it, it'll do it every time I let off the gas. Now I'm trying to troubleshoot it myself so I can bring it back to another dealer with some possibilities in mind. HELP!
Old 07-26-2010, 10:36 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
go to a parts store and get the codes checked for free
remove the plastic engine cover and inspect throttle cable assembly
where it attaches to the TB- have been several cars break a plastic collar on that and jam the throttle
if you have someone look at it- You take them on a drive, you know how and when it acts up
More when engine cold or hot? or the same etc
Old 07-26-2010, 10:37 AM
01tl4tl's Avatar
could also be a throttle position sensor
Old 07-26-2010, 12:51 PM
Car junkie
Hybridc24k's Avatar
I had a similar problem.. I just changed my plugs and it was back to normal...
peti1212
ILX
22
01-05-2022 05:14 PM
02-25-2020 09:57 AM
kuzdu
09-10-2015 08:42 PM
Mike Bertram
09-10-2015 09:27 AM
NSolace
09-03-2015 08:14 PM
Quick Reply: Pressed the gas pedal, car wouldn't accelerate...
