HID Problem....
Old Jul 26, 2010 | 12:56 PM
ThreePointTwoTeeEl's Avatar
3.2TL
Exclamation HID Problem....
My Passenger side HID comes on when I turn the lights on, but then turns off after a while. If I turn the lights off then on again, it'll come on but then shut off in a few minutes. The light is not pink.
Could it be the ballast?
Old Jul 26, 2010 | 01:31 PM
jjashaa's Avatar
Avant Garde Wheels
or igniter..
swap bulbs left to right to be sure.
if the driver bulb on passenger side does same thing.. check igniters and ballasts..
so i'd try swapping those left to right too.
Old Jul 26, 2010 | 04:34 PM
3.2TL
I know the ballast is a square box, but I've never seen an igniter.
how does it look? Where is it located?
I know I can get an HID kit for 60 bucks that comes with the bulbs and ballasts, but how about the igniter?
Old Jul 26, 2010 | 05:26 PM
01tl4tl's Avatar
ck with the sellers!!
swap bulbs as suggested,,pink on startup -when pointed at a wall- is ONE sign of impending failure
Flikker is another
So is weak output- one side to the other not same in brightness or color
replace bulbs in pairs or they do not match at all~
Old Jul 26, 2010 | 05:27 PM
01tl4tl's Avatar
wiki HID and understand how the parts work together
If you have any moisture inside the housing lens- thats got to be fixed before a full repair of lights is made
Old Jul 26, 2010 | 05:50 PM
jjashaa's Avatar
Avant Garde Wheels
#10 is the igniter
Part# 33129-S0K-A01
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
