Premium or regular gas? My experience
(Cliffnotes on the bottom)
I remember there have been many posts about what gas to use in the TL with many people using premium and some people saying regular is fine. Well after dd'ing the TL for about a year now and trying out all kinds of different gas I can give my experience (and advice).
I've always ran premium (93 here) for the first 9 months or so since beginning of 2010. However with the gas prices going up recently and having to fill up sometimes twice a week has tempted me to use lower octane gas. Slowly I tried using 89 without much changes in mpg or performance but not long enough because it was not that much cheaper than 93 so I started using 87 for maybe a month or so.
At first all I cared about was gas mileage since I was doing a lot of driving to work. I was averaging about 22 mpg with mixed driving on the premium. The 89 and the 87 both have returned similar mpg and surprisingly not lower like others have stated. So I ended up thinking there was no point of running premium gas since the mpg's are the same. However when I was running the 87 gas the car felt like crap. The car felt powerless when accelerating and it drove pretty rough. The throttle was so dull that I had to step on the gas halfway for the car to downshift. At highway speeds (only 60-65) the car felt like a 20 year old 4 cyl econobox struggling to keep the speed up and the whole car felt very shaky and unstable.
So I decided to go back to 93 to see if it was related to using regular gas and it definitely was. After switching back to premium the power came back and the throttle response was a lot sharper. Not only that the car ran MUCH smoother especially on the highways. No more unstableness only at 60-65mph, but even going 75-80 it was smooth and firm. I actually enjoy driving the car more now and feels like I'm driving a whole new car.
I know most of you guys use premium but if anyone is tempted to use regular don't do it. I used to not believe the regular/premium myth but after experiencing it first hand I could safely say these cars need premium for sure. Oh and I only have a tl-p so I imagine this is a no brainer for tl-s's. Sorry the story got a little long but just wanted to share my
Cliffs:
-Drove the car on 87 gas for about a month due to increase in gas costs
-Noticed same mpg so thought it was fine
-Car drove terrible, felt like had no power, dull throttle response, struggling at only 65-70 mph.
-Switched back to 93 and the car gained back the power and smoothness. Enjoyable to drive once again.
-DON'T USE ANYTHING BESIDES PREMIUM!
Cliffs:
Cliffs:
Cliffs:
the car is designed to run on 94 octane! but will adjust itself and deal with 91
any lower is a problem as discussed -retarded timing creates pinging etc
type S cars with their 11.something to 1 compression are just asking for trouble running less than spec gas
If you had that many issues (powerless, rough, dull, struggling to maintain speed, shaky, unstable, whatever else) you must have had more problems with your car than just the octane rating of the fuel you were using.
My dad ran 87 for about 5 years straight, right off the dealer's lot. When I first got the car I drove it as far as I was willing to risk, and I filled it up with a top tier premium gas (91 in AZ). I got a CEL the second I turned on the car. It figured it out by the next fill up, but if you change octanes, I can only imagine a simple ECU reset will speed up the process.
LOL i've never even seen 94 octanefor sale anywhere. Max I have seen at the pump is 93, and thats rare out here, mostly 91.
Chevron only has it now, used to be at all stations pretty much - but that's just where i live.
conspiracy: aspec ->canada, 94 gas -> canada
and FYI, it's 10.5:1
also OP, maybe you should try some SHELL gas too, same thing happened to me as to you switching the octane's around when i switched (i had finally found one near me, and i switched the next tank)
and the scary part is that even the wife can tell on her car, with how it runs between brands (i know people stay it's all the same, but there is enough of a difference; even if it is the same base stock/refinery; that you can feel it though)
91, not 94.
Drilling banned in the Gulf over and over again, the Alaska Pipeline offline, vast stretches of America off-limits - no wonder the prices are spiking. I paid $3.459 this morning and I was pissed. I drive 500 miles a week.
http://lubecontrol.com/
wife does like 800 a week (she fills up twice a week quite often)
I found a couple of years ago that not only does my TL prefer premium gas, it prefers Mobil premium gas. My MPG went up about 10% when I switched from el-cheapo no-name gasoline to Mobil. With the Exxon/Mobil Mastercard's 15c/gallon discount, plus my local station's 5c/gallon coupon, plus 1% UPromise, the price ends up about the same as the no-name gas anyway.
it would take 20 dollars of octane booster to do anything for a tank of 87 or 89
If you are racing the TL you already know a station with the ~good gas~
I think compression varies with year--I've heard 11 and 11.5 to 1 for type S??
mere wishful rumor??
regardless, its over 10-1 and clean pistons are important!!
Nice write up. Your TL and my accord have a knock sensor. Your ECU adjusts and will retard the timing while using 87 octane to prevent knocking. It is just not worth saving .20 cents per gallon at the expense of performance and possible engine damage.
You would spend more on a bottle of octane boost than you would filling up with 91 over regular. Adding it to 91 wont gain you a single thing other than empty pockets.
and the type S was only two years (at least for our generation of cars), so i don't see how it could vary very much
but yes the type-S is on the higher end of compression of mass produced cars, so as much as possible needs to be done to keep the combustion chamber and piston "clean"
(and i have seen a non-interference motor, bend valves before, basically because of the carbon and such built up on top of the pistons; got 12 of the 16 valves; owners where cheap, and you know that had run cheap gas regularly)
DOHC VTEC motors won't go into VTEC if motor is not at operating temp.
I have NEVER heard or had this happen to me. Low oil will cause VTEC to not engage. Especially if you are in a goo turn and most of the oil will shift to one side of the motor causing the VTEC oil sensor to detect no oil. To protect the motor, the ECU retards timing as if u hit the rev limiter mid rpm range.
but yes it will red line at 6k roughly, when the oil sloshes around (i found out, when i was burning a shit load of oil, because of how i was driving
[ 2 quarts in like 2000 miles or something stupid], my oil level is staying up now, now that i am not redlining it as much and staying in VTEC
sure...
)Vtec motors carry a lot of oil up hi. Vtec motors will burn 1 qt of oil between oil changes. Normal Drive and enjoy it. I Honda didn't want you to rev it to 7k, 7.5k, 8k, ore more. They wouldn't put redline there. You you nothing to worry about. I'd do synthetic though and you'll not burn as much. Royal Purple is my pick as it was made fore hi revving motorcycles.
that was ON synthetic (and burning that amount of oil is actually acceptable by most manufactures
), is was schaffer's oil though, which is still a very quality oil (when i got my car baselined, i noticed the performance shop was also using it too...)and 8k rpms
, done that too....., no ill effects yet from it too
and 8k rpms
With the technical arguments for/against filling up regular gas - could it be possible that the noticeable differences may be due to a placebo effect?
Just to play devil's advocate here - next time going to the pump, you should step inside the store and get something while you have a friend fill up the car for your, without telling you what they're putting in. Then have you guess if the car is running on regular or super. Do this about 3-4 times (you don't even have to fill up, about $15-$20 worth) and see if you're accurate.
I mean, dirtying up the fuel injector system, spark plugs, etc. aside - most of the obvious differences (like quicker pedal response) may just be in our heads.
What was the code set?
the RL has 11.0:1
and that engine will be even more critical to keep the internals clean to prevent pre-ignition and such
