Power steering fluid
Old 03-29-2016, 02:21 PM
7th Gear
Markus28's Avatar
Is there an alternate fluid to use besides the Genuine Honda fluid on my Acura? I've seen a Prestone Honda/Acura one but I wasn't sure if it was good.
Old 03-29-2016, 05:07 PM
TLer trash's Avatar
I'd stick with the oe fluid unless you wanted a more expensive, full synthetic fluid. There is at least one person in the 3rd gen section who has been running Redline atf, but it is not recommended by the manufacturer. BG p/n 334 is a full synthetic that they do recommend for honda, among others. You'd probably be safe with anything that specifies honda/acura on the label, but the factory stuff is reasonably priced, and wear issues are almost non-existant with it.
Old 03-30-2016, 11:27 AM
MarcDavidoff's Avatar
^ I'd agree with staying with the Honda ps fluid
Old 03-30-2016, 04:22 PM
7th Gear
WisconsinMicko's Avatar
OEM only, it is formulated to match the transmission.
Old 03-30-2016, 10:02 PM
6MT NBP UA7
MBP_TL's Avatar
I've used the Prestone for Honda/Acura p/s fluid for over 60k miles when my p/s fluid started leaking. Even after the leak was repaired I continued to use it and I never had an issue with it.
Old 03-31-2016, 07:28 PM
Yikes's Avatar
Hondas are really picky about two things:
Automatic transmission fluid
I'd recommend sticking with OE. Other's that are commenting that they've had success with other fluids: I'm glad it works for them but you certainly can't go wrong with OE.
08-16-2022 05:52 PM
guyenacurazine
04-28-2016 03:29 PM
Acuratl3535
03-10-2016 09:43 PM
tiger2471
4G TL Problems & Fixes
03-01-2016 08:39 PM
lojik
1G TSX Problems & Fixes
01-26-2016 07:51 PM
Quick Reply: Power steering fluid
