Power mirror switch illumination light bulb replacement
To separate the 2 halves the black cap of heated mirror button has to be pried off gently with a flat screwdriver first. Next flip the switch over and use a pry bar to lift up the edges to separate the top and bottom. A 12 volt bulb can be bought from an electronics supply store and soldered back on the circuit board.
racerrl
Apr 26, 2010 06:39 PM
