Post 2002 TL light bulb specs
![Lightbulb](https://acurazine.com/forums/images/icons/icon3.gif)
Please post all the exterior and interior bulb numbers for the 2002 TL/TL-S. Shoof: maybe we should use this message to update the FAQ pages.
Here we go:
Please add comments and corrections to make this chart complete!
Here we go:
Code:
2002 TL light bulb chart Location No. Wattage/candlepower Other names Qty used ------------------------- ----- ------------------- ---------------- -------- High Beam 9005 60W HB3 2 Low Beam HID ?? 2 Front turn/sidemarker 1157 22/2.2 CP 2 Foglamps 9006 51W HB4 2 Rear turn 1156 21W 2 Tail/stop 7443 21/5W 4 High mount stop 7440 21W 2 Backup 912 18W 2 License plate 168 3CP ?? Dome ?? 7W ?? Trunk 5W 1 Courtesy (front door) 158 2CP 2 Vanity mirror 1.1W ?? Map lights 67 4CP 2 Glove compartment ?? Storage compartment ??
...and then there was One
Hey now, what gives... That list shows the rear turns as being 1156, and Shyne says he has 1157A in his. Which is the right one?
I think the dome is a T6, or something like that Qty = 1 ... 12mm? The one I repaced it with is 12V/10W... Japanese SOEI thing, all I can read is 10X36.
The vanity mirrors are "fuse type" (that is the lingo the sales people at the dealership use). If anyone knows of a good replacement bulb that is kinda like an HID, or PIAA Xtreme, please let me know.
Tony
I think 99-01 TL's take different type of bulbs than the 2002's. My 99' used to take the "plug in" bulbs rather than the "twist in" bulbs. I recently changed my wiring harnest to the 2002 bulbs so they can accept the "twist in" bulbs coz they are much better.
Code:
2002 TL light bulb chart Location No. Wattage/candlepower Other names Qty used ------------------------- ----- ------------------- ---------------- -------- High Beam 9005 60W HB3 2 Low Beam HID ?? 2 Front turn/sidemarker 1157 22/2.2 CP 2 Foglamps 9006 51W HB4 2 Rear turn 1156 21W 2 Tail/stop 7443 21/5W 4 High mount stop 7440 21W 2 Backup 912 18W 2 License plate 168 3CP ?? Dome T-6? 7W 10W? DE3175? 1 Trunk 5W 1 Courtesy (front door) 158 2CP 2 Vanity mirror 1.1W ?? Map lights 67 4CP 2 Glove compartment 168? Storage compartment ??
There are two types of HIDs for lowbeams...there are D2R and D2S right? And ours I believe are the reflective type...denoted by D2R? Definitely check on that.
Austin519
Austin519
I'm pretty sure it's 912 instead of 921.
Code:
2002 TL light bulb chart Location No. Wattage/candlepower Other names Qty used ------------------------- ----- ------------------- ---------------- -------- High Beam 9005 60W HB3 2 Low Beam HID D2R 2 Front turn/sidemarker 1157 22/2.2 CP 2 Foglamps 9006 51W HB4 2 Rear turn 1156 21W 2 Tail/stop 7443 21/5W 4 High mount stop 7440 21W 2 Backup 912 18W 2 License plate 168 3CP ?? Dome T-6? 7W 10W? DE3175? 1 Trunk 5W 1 Courtesy (front door) 158 2CP 2 Vanity mirror 1.1W ?? Map lights 67 4CP 2 Glove compartment 168? Storage compartment ??
Originally posted by fahoumh
isn't any of this listed in our user manuals?
Purchased: April 28, 2001
I just ordered the reverse lights on this site and its labeled 168/921. As for the rear turn signal, I was under the impression that it uses the same bulb as the high mount brake light as that is also labled on this site. Hmmm....potential dangearous buying scenario we have here with people orderign the wrong bulbs just because of labeling errors.
I ended up ordering (today)...
For the front turn signals...
Polarg M12 (pair) - Replaces: type 1157
Hyper-White Push & Twist 35/5w=70/10w
For the reverse lights (because of heavy tint)
Polarg M6 (pair) - Replaces: type 168/921
Hyper-White Small Push-In 18w=36w
For the high-mount center brake light (also because of heavy tint)
Polarg M2 (pair) - Replaces type 7440
Hyper-White Large Push-In 21w=42w
Please correct me if I ordered the wrong bulb types so I could email Tim before they are sent out.
Originally posted by daverman
Ed: I can't find references to "921" bulbs on the web, only "912". Please double check and let us know if the bulbs work!
Thats the link to the accessories portion just as if you clicked on the tab up top. if you look at the reverse lights, its listed as 921. maybe someone should shout out an email to Tim just in case his labeling is wrong.
vanity mirror bulb????
The vanity mirrors are "fuse type" (that is the lingo the sales people at the dealership use). If anyone knows of a good replacement bulb that is kinda like an HID, or PIAA Xtreme, please let me know. [/B]
So, I am waiting to hear back from topbulb.com, they are supposed to be the place to find unusual\hard to find bulbs.
I am hoping they can give me some name\type for the bulb and then try and find a superwhite type replacement. I will keep you guys updated.
