Popping sound when starting engine?
Old Jan 8, 2003 | 12:06 PM
I have a 03 TLS w/ 8k mi. and wondering if any of you experienced a popping sound when starting the engine cold? I've taken it to the dealer twice and told me its normal the first time and couldn't duplicate it the second.
Also, can you recommend a dealer/independent dealer for good servicing in the San Fernando Valley/LA area?
thanks.
Old Jan 8, 2003 | 12:13 PM
I find I have to hold the key in the crank position for an extra second or two to get a good start in the cold...
Old Jan 8, 2003 | 12:20 PM
doopstr's Avatar
The popping sound is most likely the motor mounts. They are gas filled. I don't know the details but they have been known to do that during startup and is considered normal.
Old Jan 8, 2003 | 12:51 PM
Do you hear this 'pop' when starting your car? Thanks for the updates.
Old Jan 8, 2003 | 03:15 PM
this is me's Avatar
yep, happens every time. I hear a quick pop (sounds like it came from the dash) just before it starts. I think its normal because its like that since the first time i drove off the dealer.
Old Jan 8, 2003 | 03:29 PM
Mr Zipps's Avatar
Yeah that is a normal noise. Just like DOOPSTR said its the motor mounts.
Mr
03 ABP TL-S
New Jersey
Mr_@yahoo.com
Old Jan 8, 2003 | 03:49 PM
Gilgamesh's Avatar
Same with the buzzing you hear when you drive off...that is the mounts coming to pressure (I believe)
Old Jan 8, 2003 | 03:57 PM
T Ho's Avatar
That's the ABS motor self-diagnostic.
Old Jan 8, 2003 | 07:52 PM
ElegantTL-S's Avatar
¤ Club Inspire ¤
Funny, I don't hear no popping noise when I start the car. I believe it did it only twice during break-in period.
Old Jan 8, 2003 | 08:00 PM
fla-tls's Avatar
On the way!
Mine only does the pop if I leave the car sit for a while (like overnight).
Old Jan 9, 2003 | 10:01 AM
AndySara's Avatar
Your engine mounts are vacuum controlled. They will emit a "popping" sound when you start you engine (similar to you putting you hand in front of a vacuum cleaner hose). Once an engine is off, depending on how efficient the seal is, it might not release instantly. That is why some of you do not hear the popping noise when you re-start your car warm (It will only happen again the next day when the engine has a chance to get cold)
Old Jan 9, 2003 | 01:10 PM
doopstr's Avatar
More like a thump. Like the others I get it when its been sitting cold for awhile.
Old Jan 9, 2003 | 08:34 PM
LiQiCE's Avatar
Liquid Ice
I noticed that this only happened to me when the weather started getting colder. The colder it is outside (or in my garage) the better the chances of hearing the noise. Additionally, I found if you put the car in the "On" position (running off of battery, engine is still off) and let it "warm up" up (wait until maybe after the fuel gauge goes up and the stereo / navi turns on) ... then crank the car to start the engine, you almost never get that popping noise.
I have started to make it a habit to just have the car sit in the on position for a few seconds before actually starting the engine. I forget the explanation I was told on why it works this way... but it has been pretty consistent for me!
Old Jan 10, 2003 | 10:59 AM
Thanks for the inputs. Its normal/safe to hear the thump/pop at start up. Will try what 'LiQice' submitted. Thanks.
Old Jan 10, 2003 | 11:27 AM
AndySara's Avatar
WAIT !!!!!!
You WANT to hear the thump.
(Just depends on whether it is a loud or soft noise)
No thump....NO vacuum seal.
Considering your engine block is sitting on vacuum seal mounts...
you go figure.
Old Jan 10, 2003 | 12:39 PM
T Ho's Avatar
I don't think you "want" to hear the thump. The thump is the engine mount hitting one or the other of the hard stops, inside the vacuum/hydraulic mechanism.
I'm going to get to the bottom of how they REALLY work. Then, we'll know.
I think Liqice might be onto something, though.
Todd
Old Jan 12, 2003 | 10:33 AM
eggbert's Avatar
Yeah.. more like a thump. I always think it's a small boom.
_
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
Iain MacLeod
Sep 17, 2015 01:01 PM
Tsov Tom
Sep 6, 2015 07:56 AM
