Please Help - What is the best way to remove a spark plug
Old Apr 24, 2009 | 09:42 PM
mohamed.ali24's Avatar
What is the best way to remove a spark plug that was dropped in the wrong way into its' slot?
Earlier tonight, while inspecting a spark plug, I went to insert the plug back in by hand. I then dropped it with the wrong end facing me. Now it's stuck in its slot and I need a solution in less than one hour!
Please help,
Old Apr 24, 2009 | 09:47 PM
6MTUA5's Avatar
No He Can't
You need a spark plug socket and a long extension
Old Apr 24, 2009 | 09:52 PM
I have spark plug socket....The problem is since I dropped the plug in the wrong way, the socket doesnt attach to the plug like it would in a normal situation.
Old Apr 24, 2009 | 09:58 PM
6MTUA5's Avatar
No He Can't
Put a thin rag over a pair of needle nose pliers?
Old Apr 24, 2009 | 10:02 PM
This sounds like a good idea,
Now, I'm going to try and find long needle nose pliers
Old Apr 24, 2009 | 10:42 PM
Bearcat94's Avatar
AZ Community Team
One of those magnetic picker-upper things.
Old Apr 24, 2009 | 10:45 PM
6MTUA5's Avatar
No He Can't
I was going to say that but wasn't sure if the magnet would mess up the spark plug in any way
Old Apr 24, 2009 | 10:51 PM
TLin401's Avatar
'13 Hyundai Sonata
I used that to take mine out and put mine in and it turned out fine.
Old Apr 24, 2009 | 10:54 PM
totaledTL's Avatar
How could a magnet mess up a spark plug?
Old Apr 24, 2009 | 10:59 PM
6MTUA5's Avatar
No He Can't
Mess up the electronics inside it
Old Apr 24, 2009 | 11:02 PM
fsttyms1's Avatar
Needle nose
totaledTL's Avatar
There's no electronics in spark plugs.
Old Apr 25, 2009 | 12:34 AM
Thanks for all the ideas everyone,
After using a deformed coat hanger, a flash light and making a lot of prayers, I was able to hook the spark plug with a hooked end of the coat hanger and pull it out.
Now 5 more plugs to replace on another day.
And SEAFOAM SOON! =)
Old Apr 25, 2009 | 02:30 AM
adamlee05's Avatar
Thread Police Chief
nothing wrong with an good guess
Old Apr 25, 2009 | 05:07 AM
01tl4tl's Avatar
since you only did 1- go ahead and seafoam now- then a few days after foam-- change the other spark plugs
Its just to keep crud off the new plugs
To make life simple- use a foot long piece of vac tubing, it will slip over the top end of the spark plug- allow you to lower it in place and tighten gently with fingertips
If you start to cross/mis thread the plug the hose will slip
Use a small amount- a few middle threads of the plug- with plug anti sieze, makes them go in smooth and easy out next time
Handle the coils like fine glass- any slight dropping will damage the coil internally
Old Apr 25, 2009 | 10:01 AM
6MTUA5's Avatar
No He Can't
I'm not saying that it's like a smart bomb inside a spark plug, but there is SOME stuff in there that you might want to be worried about.
Old Apr 25, 2009 | 10:58 AM
01tl4tl's Avatar
messing up the gap would be the main concern- to me- when dropping a plug as described--and having to retrieve it
Old Apr 25, 2009 | 02:31 PM
adamlee05's Avatar
Thread Police Chief
so THATS what a spark plug is!
Old Apr 25, 2009 | 07:34 PM
01tl4tl's Avatar
see why ours cost 7 bucks each- not 2!!
And compare that pic to pulestar plugs pic and how their innards look and work.
While they have not proven a huge improvement in the TL,
~1-2mpg when installed at 50k, so that improvement could be from any new plug.
No one has done new ngk irid for a month, then pulseplugs for a month to test the actual mileage increase-if any- we have a high efficiency ignition already
I am going to try 4 in my honda 2 wheeler and see what they do with a standard coil and plug wire setup...you can tell right away if the power or torque has changed on the bike
Old Apr 25, 2009 | 07:36 PM
01tl4tl's Avatar
heyyyy thats not an iridium plug!!! it says platinum or gold palladum!!
LeVeL
Oct 18, 2015 04:19 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
polish_pat
Sep 25, 2015 12:24 PM
STL TL-S
Sep 23, 2015 08:52 PM
Cexarin
Sep 23, 2015 07:43 PM
