Please help: Car wanders
Old 12-30-2009 | 08:27 AM
YeuEmMaiMai's Avatar
2002 CL type S with 90K miles
I tried posting this in the CL forum but they are sleeping on the job or are recommending things that have already been looked at
some background
my car had a slight wandering problem before I had an accident and it is much worse afterwards but I do not think the work of repair shop has anything to do with it since I think it is more due to some new parts being used in the repair process that makes the problem more appearant. the car also does not have any of the "looseness" that it had before the accident.
just before my accident I had new lower ball joints put on the car and it almost completely solved the problem but not quite
I curbed my car and the following was replaced in the front
subframe
right side LCA
A/C condensor
front exhaust pipe
skid plate
tow hook
bumper cover
the following was repaired
upper and lower tie bars
fender
door
they repaired the car perfectly and it does not pull it just wanders and I need to know exactly where to look in order to resolve this issue. The car is going to Acura on the 11th for an allignment but I think this is a worn part issue versus an allignment issue.
any help would be appreiated.
Old 12-30-2009 | 08:52 AM
jonmizu's Avatar
interesting well my friend has an sc300 that if you drive wit the steering wheel straight it starts to uhh well "wonder" and you gotta counter steer left and right to make it go straight if thats your problem he told me that was because his tie rods needed to be replaced gotta make sure the tie rod bushings i believe theyre called got replaced/fixed also
Old 12-30-2009 | 09:40 AM
assclown's Avatar
2000 acura tl FPR
get the car some blinders, problem solved
Old 12-30-2009 | 10:45 AM
01tl4tl's Avatar
was an alignment listed on the invoice?
what were the final readouts?
that MUST be done, and should have been done before you picked up the car
What is `repaired tie bars`- the tie rod ends? you replace those in a curb shot accident, the side force will kill them and is the adjustment for Toe on the alignment- the thing that makes the car go straight~
Thats a good place to start looking, as those will also allow the alignment to change constantly- you could set it and drive a block and its moving with each bump = wander
Take it back to the shop and tell them its not right
I have seen shops not do work and charge for it, then if the customer comes back they do straighten whatever..if not they made free money
Old 12-30-2009 | 10:58 AM
tie bars are part of the bulkhead in the front of the car.
yes there is an alligment on the invoice and the car does not pull to either side
Old 12-30-2009 | 02:40 PM
spoka's Avatar
get back to gdd :P
Old 12-30-2009 | 03:23 PM
^ lol
I am still in there
but I really need help with this cause I don't want to be tossing money....
Old 12-30-2009 | 04:46 PM
01tl4tl's Avatar
if the toe is off it can wander, doesnt have to just pull to be wrong alignment~
my 01 does that since wife finds every pothole to put those enkei rims thru
Now it needs 2 front tires, bad wear on inner edge of both
Thats what I get for not driving it very often now to keep an eye on things-
...got a bike and the TL became `her` car again~
Old 12-30-2009 | 04:47 PM
01tl4tl's Avatar
I would check the tie rod ends for sure- often damaged in curb shot accidents- dont ask how I know
and general wear- your past problems etc,,look at the basics
Old 12-30-2009 | 04:59 PM
^ thanks, we'll have acura check it out and go from there
Old 12-30-2009 | 05:04 PM
friesm2000's Avatar
B A N N E D
as said befor how are the roads you drive on
also you may not have enough caster ethier, does the force that it takes to turn the wheel seem a little light (too easy), or like it was before???
Old 12-30-2009 | 05:07 PM
car wanders over everything asphalt, concrete, dirt...
Old 12-30-2009 | 05:14 PM
friesm2000's Avatar
B A N N E D
so even like newly paved roads too, cause worn roads with ruts, are hell for trying to get a car to not wander
just trying to make sure it was not the conditions of the roads causeing the problem
Old 12-30-2009 | 05:16 PM
friesm2000's Avatar
B A N N E D
also how does the steering feel, light, normal, or heavy
and is it the same as before too
also the printout with the current alingment on it would be killer, to help figure out the problem, but you proably don't have it , body shop proably does
Old 12-30-2009 | 05:19 PM
actually the steering is alot tighter like it was when I bought it
Old 12-30-2009 | 05:38 PM
friesm2000's Avatar
B A N N E D
thats good, but i mean more like is it harder to turn, as before/normal, or does not take as much effert to turn the wheel
like in a parking lot
Old 12-31-2009 | 04:37 AM
01tl4tl's Avatar
need the alignment printout after all the repairs to know if anything is off to start with- go from there
This car took a major side slap to the front and went off roading after that~
Im just trying to prevent a delay by waiting for dealer to inspect and need a part, when the repair shop should be able to get it on the lift and see whats up
If a locknut on the tie rod was left loose--something like that would be good to fix now.. not 12 days from now-
but thats just my opinion--and I have been wrong several times this year
Old 12-31-2009 | 11:35 AM
unfortunately the repairshop did not do the allignment, the shop subletted it and they were the ones that found the bent LCA on the passenger side. I will get the print out from Acura on next friday. The soonest I can get it back to the repair shop is next friday Work 12 hr days = everthing closed before and after you work.
Old 12-31-2009 | 11:41 AM
no there is no binding and the steering is the same as it was before effort wise (the CL-S steering is not as boosted as the Premium model) car responds immediately to inputs
Old 12-31-2009 | 01:15 PM
friesm2000's Avatar
B A N N E D
effort wise would be a better explanation of what i was asking
and i got a TL-S and i wish the steering was still stiffer then it is now, guess i like the steering being a little stiff
depending on how far you work from the shop (if you could walk or get a ride to work) you can always drop it off before they open with your keys, and then pick it up afterwards, and do everything by the phone, to maybe get it in sooner
Old 12-31-2009 | 01:42 PM
01tl4tl's Avatar
not driving the car too much without inspection is our basic concern- for your safety-
would hate to lose a good member who helps so many
Holidays always suck for getting your car looked at
Shops are desperate for money...need I say more...buyer beware on diagnosis
Is there another alignment shop near you that can put it on the lift for a quick check?
oh Yeah- Merry new Years everyone!!!- lets arrive safely into 2010
peti1212
ILX
22
01-05-2022 05:14 PM
02-25-2020 09:57 AM
Legend2TL
Motorsports News
01-31-2016 09:27 AM
kuzdu
09-10-2015 08:42 PM
jordanboi
09-05-2015 01:33 AM
Quick Reply: Please help: Car wanders
