Please dont tell me that the transmission is bad again
I drive a 2000 Acura TL. I got it like 2 1/2 years ago with 100k.Before I got it they did the 100k services(water pump/timing belt) I love it. It ride smooth and never had a big problem just change the battery,temp sensor,spark plug, and normal 3000 mile oil change.I had acura look up the vin to see if anything was change on it when I first got it. It came back saying that the transmission was replaced at 80k. Now I hit 160k on it. I have two little problem hoping that it doesn't turn in to a big one lol.When I have the car running in park or neutral it shakes enough to bug me. If I put in in drive it will not shake that much very very little and hard to feel. Next problem is when I am going up a hill my car will shake(maybe slipping hoping not) at 2000-2500 rpm only. Any idea? I have never change the transmission fluid. Will it help if I change it? I have heard if you change the transmission on high mileage car can do more damage then before. I do all the repair on this car and have not seen any fluid from the motor mounts.
S E L L
You getting the Check Engine light? Is it on solid or is it flashing? It kinda sounds like a mis-fire. One of your coils could be bad but get the codes read first to be sure.
No CEL now. I had a high temp. sensor code about two months ago. I just replace the sensor and no more CEL. I thought that it may be a mis-fire too but no code for the coil pack and i replace the spark plug with Ngk-Ix-Iridium plug
S E L L
Hmm, with the kind of symptoms you're describing I'm surprised you have no CEL or any other flashing indicators. It still sounds like a mis-fire though. You might have to get it checked out at the dealer.
ok Thanks for the input. My last resort is taking it to the dealer I hate paying dealer price on everything lol Anyone else have a suggestion?
:( Harminder Is Lost In
It is a bad idea to change the transmission fluid if your tranny is acting up. This will cause it to go out much faster. You should have changed the fluid between 30-40k imo. If you have the money for a new tranny, i would take a risk and change the fluid. Better to find out instead of getting stranded somewhere trying to save some money now and spend more on towing later.
changing the entire transmision is ok- but dont change the trans fluid!!!
I agree on misfire and will explain that during plug change its very easy to damage a coil without seeing it, then some months later it fails and causes rough running
if you are in the USA go to major name parts store and ask for a free code check
best method:
Smell the trans fluid on its dipstick, burnt= bad - not burnt = good!
best method:
you would have to have more than 2 motor mounts broken to get the shake OP described
Most trans failure customers had no idea the front mount was broken when they come in.
OP also had a sensor prob that went unfixed for a few months, no tellng what may be loaded up now~
SEAFOAM!!! and get the codes checked even if no CEL showing- it may need a coil
climb under the car- or car on ramps- and look directly up at the front and rear motor mounts- those are the fluid filled ones, but constant vibration shake sounds like ignition
best method:
best method:
I will look at it hard next time I put the car on the Lift at the shop
If your tranny is acting up, old fluid will kill it down the road anyway. Nothing will run on old fluid forever, and I don't think the manual said tranny fluid is a lifetime fluid, maintenance free. New fluid either resolves your tranny symtomp or will kill the tranny. I don't see much difference that the tranny will die in 3/6/12 months with old fluid or will die now with new fluid. If it does not die with the new fluid, then you are actually saving the tranny. If it dies now, it is as expected as long as you are prepared for it and get a loaner like mine. I would do one drain and refill and see how it goes. 25 bucks for the fluid is worth trying.
I may just take it to Acura. Pay out my ass and have them check everything out. I am guessing it would be around $100 for them to look at it? I will talk to one of the tech about the transmission fluid change. What do they charge to look at the car and change the transmission fluid? I never take my car to the dealer
Id say thats a bad idea. My car was at 99,8XX and the tranny i thought was going to go out. Took it to the dealers and they charged me a 100 saying nothings wrong and its the mounts acting up. If it were the transmission i would have to pay they stated. Car hit 100,050 and tranny its slipping like hell broke loose. I took the car in all pissed and they had nothing else besides the mounts are what caused it. I looked at the mounts and they were good. I dont know how the dealers there are but your better taken it to a private shop if you just want their say on what they think it is.
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
I just had my car shake like a mofo and throw all kinds of codes p0302, p0304, p0305 p0300 and p1399 the first fout where misfire code in cylinder 2,4 and 5 .. I changed a coil pack in cylinder 4 and runs like new.. If its not throwing codes i doubt that is it.
It prob is a engin mount that is broken..
when you accelerate slow;ly does your tranny grind do u feel it grinding when acelerating slow?
BTW i would change the ATF fluid easier then changing oil!
harmz- PM me if you need help at the dealer on trans warranty
Bad Toys Tuning
Does the rpm surge ? and does it do it in D5 Gear.. i have the same problem.. mine started 5 months ago and i still have no check engine light.... buh it's getting worse.. i get bad gas mileage and low rpm idle when im cruising at 60.. and powerloss.. i replaced everything that has to do with idle.. the only thing i didn't replace is o2 sensor..... few technians told me.. most likely it;s the o2 sensor becasue as soon the car warms up from start it drives fine for first couple of minutes. and then the problem starts...which makes sense for the o2 sensor to work once the car is fully warmed up...
Idle say the same that i can tell just shakes in park and neutral. When it first started to happen i thought it was just because my a/c was on but if i cut it off it the same
Is your idles say 750-800 rpm or lower ? Why don't you try to reset the ECM by removing
the passenger side fuse # 13 ( 7.5A) for the clock back up for 2 min and re-install the fuse.
Then do a idle learn procedures :
Start the engine ( do not turn on any light , radio,climate control ..etc ) and to load.
Let the engine run and do nothing until both fans run and cycles twice (normal temp)
Then let the engine idle for and extra 10 min.
Then just drive the car ........................
This idle learn will let your engine idle fine and the ECM will compensate for any load that you will add on later ( AC , Reardeforst , headlight ..ect )
Bad Toys Tuning
drive it in D4 and see if it's in low rpm while your driving.. and let me know.. casue i have the exact same problem in D5.. casue i used to drive in D5 all the time. and i switched to driving in D4 to see if it might be a transmission problem but it's the same issue * LOW RPM* and pretty much sometimes it hesitates i changed everything EGR Valve, Coil packs, Sparkplugs, EGR Port cleaned, checked the coolant, throttle body service,IACV , MAF and nothing worked.....
My first thing i would look at and replace are the motor mounts. Especially if they havent been replaced yet with that mileage
Coolant in transmission fluid is Pepto pink
Any help please, I've replaced timing belt water pump had rebuild transmission some soliniods replaced, soon after this happens I'm putting so much into this car I'm afraid to buy a anything for it again, a weak after buying timing belt kit and pay for help, I need some fresh info please what to do. Flushed radiator drained out pink stuff, waiting for a nother part ordered warmer/cooler interchangable that fits on train not radiator, BDGA trany.
joflewbyu2
10-08-2015 11:16 AM
flyromeo3
09-24-2015 11:24 PM
