passenger side door lock button not working?/
has anyone had this problem??
i have a 99, which i've had right at 3 years, and somewhere along the line (maybe before i bought it) the passenger-side lock button stopped working - it does nothing
any ideas guys??
something i could take care of myself??
any ideas guys??
honestly i'm not sure when it stopped functioning - for all i know, it coulda been that way when i bought it, but i have no idea, i've never used it, obviously
i just noticed it when one of my passengers brought it to my attention
if it is the "lock wire", is that something pretty easy to fix myself, assuming i can get the door panel off??
I can only think that the wire harness became lose or someone else forgot to plug it in. If its not that, it may be other electrical problems. To get the door panel off, you have to unscrew like 3 screws on the door, including the one where the interior door open lever is. You have to slide the door lever assembly to the right then unhook the metal connecting rod behind the door lever assembly. After that, you pry the bottom part of the door panel out slowly, theres like clips that pop in and come out easily with some force. Once you get the bottom half of the door panel loose, you have to push the door panel upward, since the panel is basically hanging on the jam where the window is. Hope that made since.. once you get the door panel loose, you can only bring it out about 6 inches b\c of wires behind it, just look behind and make sure everythings in tact.
05 C230K & 09 135i 6MT
My 99 Accord has this problem.. it works sometimes, doesn't work others. Lately, hasn't worked at all. I was told it was the actuator, but to me it doesn't make sense that it would work some, not work some if the actuator was bad. All you can do is have it checked. If, like me, the only problem with the car (in 89.5k miles) is the door lock, it is pretty minor.
cool - i really appreciate the help guys
obviously it's not a huge problem for me, since i'm on the other side of the car, but i'm thinking about selling soon - and I'd want to get all the little little things taken care of and working/looking like new
when i get a free day here, i'll probably try to get the door panel off and take a look back there
again, thanks a million guys
Карты убийцы
Check the fuse panel. Also there should be a little black contact plug at the bottom corner of the door where it opens. It this unit is worn-out then the door lock will often not work.
tman570
06-11-2019 07:56 AM
justin7779
12-25-2015 10:33 PM
