Passenger low beam HELP!!
Just got an 01 tl with no low beam bulb or cable im guessing. I dont know if i just need a new cable to connect the bulb or what. Thanks in advance.
You need a ballast as that connector plugs into a ballast and then the HID.
I would say use this: https://www.theretrofitsource.com/ma...AIR?quantity=1 to repair your whole system. Make sure to pick the D2R bulb which is the right one for your year car.
