Painting the Y pipe
Painting the Y pipe
Anyone know if it makes a difference if you sand the surfice before u paint or treat it with some rust removing chemical? Do I have to take it off or can I paint the pipe while it on the car?
I want to do it before th ewinter comes and the snow and salt beat up the exhust.
Sanded it down first to remove all dirt, and for best adhesion. If u get Rustoeleum paint, it'll take care of any possible rust, etc. Anyway, that pipe is stainless steel and you're seeing discoloration not rust. Dont need to remove it. I just crawled under and sprayed it several coats. Looks so much better black.
Ed
i've done mine..only cost me 5$ canadian... and it looks so much better... i didnt sand mine down...too lazy and dont kno where to get sand paper hehe... i juss cleaned it realy well and plus my car was new so there werent too many sh!t on it...
got some high heat bbq paint...flat colour... and sprayed it bout 6 layers? lots... i'll try to scann some pics...
I painted mine when it only had about 2K miles on it. There wasn't any rust on it so I didn't bother sanding it. I've got 7500 miles on it now and no problems. Looks freshly painted.
If it comes off, I'll paint it again. I've got plenty of paint.
got mines in silver
its good to have it.
i took off the whole cat back up to where cat. convertor was.....
must sand it other wise some parts that are rusted will start to chip off and all your work goes down the drain you'd have to do it over,
im talking bout the most important part is where the 2 separate pipes meet, sand em hard cause badly rusted, should see a good shiny silver silver underneath,
if your behind me with your car you'd see it
its the same thing in hi heat, but got in silver from home depot,
i think there was white color also.........
Originally posted by Shoofin'TL
I sanded it down with 100 grit sandpaper...it's recommended...better adhesion. I got plenty of paint and sand paper....if ya want, i can help ya out..
Ed
Ed
I am painting mine hopefully soon too.
Originally posted by BlackShadow
Since you got plenty of them, hook a brother up with paint and sandpaper Ed.
Originally posted by fahoumh
hey, did you guys use spray paint or did you brush it on....yeah, I know this is a dumb question, but I want to know before I do it and make a big mess.:p
Jul 16, 2017 07:33 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
johnpancakes014
Sep 27, 2015 12:58 PM
