P1739/1740; shifts fine; what if I do nothing?
Unregistered Member
Yea I got that same code. I reset it a couple times, but it kept coming back. The dealership used their flush machine, and the light never came back on. Say what you want about flush machines, but the official Acura machine saved my tranny.
30k miles later, no problems.
everything i've read/ heard states " don't use the machine". Sperry - did you try cleaning the solenoid screens ? I'm far from a mechanic or an expert, but maybe the code is coming up because of lack of fluid from the screen ??
I'm going to take them out next weekend and clean them.
On another thread, the guy cleans them, and the code came back a few months later.
As long as inaction will not cause the transmission to overheat or immediately implode, I'm cool.
I priced the parts, and a new gas cap. $125 delivered from acura oem parts online. Backup plan.
Im guessing the acura machine is made to work with the newer acura transmissions
if they use it on ours with good results = awesome!
are they really changing all the fluid? not just 3 qts, and what was the cost?
other trans shop machines often use dextron3, the very fluid thats not allowed near the TL!
start with cleaning selenoids before replacement
some new pics would help others
fix it. If you dont it can cause more wear and failure faster. Those lights arent dummy lights that dont mean nothing.
Let me clarify. Do I need to park the car and take the bus until it is fixed?
Would you try cleaning, or cut to the chase, and order new parts?
I think kris means ~dont ignore the lights~, they indicate a real problem that failure to do anything about = will result in damage to the trans
You already plan to remove the selenoids/clean- the screens are underneath iirc
and have a backup plan to purchase new parts if needed
So thats considered being active in the repair
drive short distances as needed until its fixed
who has the good info on this job?- is it in the diy.. or next to the diys?
pretty sure I have seen pics here
just saw you have 151kmiles,,original trans?
Go ahead and order those new parts today,,thats plenty of life to justify replacement
Unregistered Member
If it's original, it's going to die.
The fluid looks new. I did a 3 x 4 last year, at 103K; probably the first time it was done.
Did a 3 x 3 a few months ago, and it was looking healthy after the first three came out.
Just ordered the parts. Well, at 152K, it's either fine, or this is the end, and I have another few months left.
Thanks for the clarification on expected component life.
I've read that some guys do this replacement as a general wear item.
28600-P7W-003 SWITCH ASSY., OIL PRESSURE $44.27
28600-P7Z-003 SWITCH ASSY., OIL PRESSURE (TEXAS INSTRUMENTS) $48.41
90471-PW7-A00 GASKET (10MM) 2 $1.91 $3.82
17670-SM4-A04 CAP, FUEL FILLER (TOYODA) $17.16
SidhuSaaB
05-30-2020 12:40 AM
Hines57
09-24-2015 01:58 PM
