p0700?
Old Dec 29, 2013 | 07:19 PM
newkidontheblock's Avatar
p0700?
01 Acura tl
anyone ever have this code says something about computer
Old Dec 29, 2013 | 09:07 PM
Nicks2001tl's Avatar
I`ve never had this code but for sure know it is transmission related. Usually it means something is off on your transmission and you need to get it scanned for possibly more fault codes.
Sometimes you can clean your solenoid screens and change the tranny oil and tranny filter, that might do the trick to erase the codes after you reset the computer.
Some more info couldn`t hurt, like is the oil level correct or is the transmission fluid discolored or smells burnt. Does it shift funny?
Old Dec 29, 2013 | 10:19 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Have a look at the ground cables attached to the body and transmission, also check all the the wires on each of the connectors on the transmission (might be a short to ground) any wire that is touching a metal surface and is broken is the likely culprit.
Like Nicks2001tl mentioned check the oil level, maybe its overfilled.
Old Mar 23, 2016 | 09:11 AM
EM2typeflex's Avatar
This thread right here has been a big help to me, thank you to those who posted in it. There are alot of threads with the p0700 transmission code BUT not many with this code by itself.
brynnsuzanne
1G CL Problems & Fixes
Aug 13, 2015 01:02 AM
2doe
1G TL Problems & Fixes
15
Jan 28, 2013 06:11 PM
guacka
Feb 10, 2011 02:10 PM
pretty_ricky302
1G TL (1996-1998)
Aug 31, 2008 01:58 PM
qstorm78
Sep 7, 2007 06:13 PM
