p0401
Clean your egr port. Since you have a 1999 like me there is just one egr port to clean. You need throttle cleaner and a toothbrush or clothes hanger to remove the crud and carbon build up. Takes about half an hour.
You need to remove the plenum and your set.
There is a DYI for it for second gen.
yep- time to clean the egr port system from valve thru intake manifold
you will need to ORDER a tb to manifold gasket- no shops stock them
Rob_lowrider
1G CL Problems & Fixes
02-20-2014 05:43 PM
