one bolt=one obstacle
Old Aug 20, 2001 | 06:04 PM
dimsumo's Avatar
I have decided to take out resonator box. I took off the fender well and I see a box under the air filter. Now I see one brass bolt holding the resonator to the metal. I can't take off the bolt, I even used a power drill but it won't budge. I guess I need more power(air pistol). What else can I do? Do I even need to take the bolt out or is it the wrong bolt?
Old Aug 20, 2001 | 06:27 PM
Bitium's Avatar
Retired MOD
Re: one bolt=one obstacle
Humm, there should be 2 bolts on the top corners of the box. They are quite easy to remove, you don't even need a drill. There is another one in the midlle of the box, which you should not touch, I think this is the bolt you are traying to take out. . Good luck.
Old Aug 20, 2001 | 10:24 PM
dimsumo's Avatar
So it is two bolts? I think I was trying to take out the wrong bolt. Opps
Where are these 2 bolts. Are the heads facing down or towards the front engine?
Old Aug 20, 2001 | 11:15 PM
Bitium's Avatar
Retired MOD
The are facing the side of the car.
Facing <---- View car from the top
.1 <- s F r o n t
.2 <- i
........d
........e
Hope my patented illustration helps
Old Aug 21, 2001 | 12:27 AM
Lawaia's Avatar
Moderator Alumnus
.1 <- s F r o n t
.2 <- i
........d
........e
I give you 2 points for creativity!
Old Aug 21, 2001 | 09:48 PM
dimsumo's Avatar
I see.... I'll check it out tomorrow
Old Aug 21, 2001 | 10:55 PM
99WDP's Avatar
It will be alot easier to remove the front bolt if you remove the bumper first. I didn't and it took forever to get that front bolt out.
tsx_boy
Dec 13, 2019 08:33 PM
neuronbob
23
Jul 16, 2019 10:48 AM
Charles Bennett
Jan 28, 2018 08:53 PM
kev87a
Oct 18, 2015 02:03 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
