oil pan
oil pan
I searched online but couldn't find a direct answer; Are the oil pans from the 02 TL's aluminum or steel? I cracked my oil pan and i'm pulling it out to either replace/weld. I spoke with someone from a muffler shop and he told me that they cannot weld aluminum pans. Please let me know, thanks!
EDIT: I took off the J-pipe and all the bolts holding the pan but I can't get it off. I was thinking about sticking a flathead to pry it off.
You may be ok with JB weld or personally, I would replace it (see if you can get a used one at a junk yard). New one is about $100. Getting the pan welded will probably cost you more than a new one (quality job, certified, etc. that is)
But yeah, the sealant is pretty strong. Just pry slowly. Won't hurt to heat it up a bit.
Get that sucker welded! Just don't ever get your block welded like a customer had done to his civic. No wonder it had a missfire.
http://www.handsontools.com/OTC-Tool...-_p_45260.html
You need this tool. I dislike the price though, you jam the blade part there in between the pan and the block, then tap one end all the way around. I'm using it next time.
IBankMouse
Jun 13, 2020 12:53 PM
