Oil in intake manifold.
Yes normal. Dont worry about it
Originally Posted by MurkyRiversTL
Why is that normal?
Mine
I cleaned up the oil & removed the sooty deposits.
Is it ok to reuse the gasket?
Not sure on the bolt torque.
I don't have a service manual yet, difficult to get one.
Moderator Alumnus
Originally Posted by GreenMachine
^^^Gross dude, clean that out.
It is normal.
It is normal.
This make you happier?
Did you remove the intake completly and clean out the ports?
Yes reuse the metal gasket
Its like 11ftlbs (i dont have my manual here to give an exact)
I also did this too
Is That clean enough for ya???
Ok good
Cleaner??? the first pic is oil and carbon, i used cleaner on that. The other 2 pics is the Polishing i did to the rough cast aluminum. That required a few hrs of sanding with the grinder and dremel
Wow, you made that manifold look brand new.
I just removed the top cover plate. Maybe when the weather warms up
i'll remove the intake.
I use a shop vac to pick up the loose carbon. And i used Brakleen for that
stubborn stuff.
stubborn stuff.
stubborn stuff.
stubborn stuff.
to just remove and clean a hr a half or less. To P&P like in teh 2nd pics a whole packer game and part of the 2nd header game
Dont get the lower 4 pics confused with the upper ones. They are 2 completely different things. the upper ones in most TLs are needed every 60k or so, many even less. Carbon builds up due to the design.
IBankMouse
06-13-2020 12:53 PM
lanechanger
10-13-2015 10:56 AM
STL TL-S
09-23-2015 08:52 PM
