oil expert and cross country road trip question
My car is about 82K. I changed oil 5-20 Mobil1 500 miles 2 months ago. Then, I used the car for a month and let it park at home in FL for a month while I was out of town. Now, I am coming back home and want to take the car cross country? (FL-CA 2800miles )
Should I replace the oil before I start the car again? Or just use that oil and replace it when I get to CA after about 3000 miles.
I already changed the spark plugs, replace new trans @ 78K (warranty), and replace the rear pads, my mechanic said front pads have about 50%, seafoam the car w/ last oil change.
I also plan to replace the timing belt, water pumps, and TB tensioner. Is there anything I need to do with car before I take it for the road trip?? Thank everyone for your input.
The T/B and W/P after 105,000 miles.
Miner
S E L L
Yes you are dumb. You are wasting natural resources needlessly. You aren't gaining anything by changing the oil that often and you might start pissing people off at your job. I know I'd be pissed if one of my employees was taking advantage of complimentary oil changes. Unless they aren't really free and you're just stealing them. So once again, you are stupid and/or dumb.
Make sure to check all tire pressures and set 2 psi higher than normal for the trip
Check the spare and tire change tools
Seafoam the gas and dont sweat the oil. 15 minutes driving and its burned off the moisture buildup
Enjoy the trip- I would put 3000 on my TL and not do anything but check the fluids and lights all working
2002 Acura TL-S
gfaze, you dont know how my dealership is run, so dont put your 2 cents, if you want to take a private tour, let my secretary know, and we can book you up on a tour. sorry for being stupid.
bringin lead
^^regardless - you're still wasting resources with ZERO benefit.....i bet you let your water run and leave your lights on all the time at home too....btw your secretary thinks you're dumb also.
SixSpeedDreamin'
I change my oil every 3.5k-5k, sometimes I go beyond 5k depends on the money situation. You should be fine traveling 2800 miles.
ostrich
09-11-2015 04:28 PM
asahrts
09-04-2015 05:55 PM
