oil change on a slope?
Old May 19, 2004 | 12:54 AM
asloudasitgets's Avatar
i read a thread that said you can do an oil change on a slope while your front is facing downward?
doesnt the car have to be flat so that all the oil can drain? or can you do it on a slope?
also i am so confused about where to put the jack stands. i know where to lift the car, using the little metal tabs right beside each wheel to life the car, but where exactly do you put the jack stands? everyone has a different answer and i have never been so confused or frustrated in my life. Even on the s2ki.com page no one can give me a straight answer to lift my s2000.
Old May 19, 2004 | 11:00 AM
Severin's Avatar
Regarding the draining, since the drain plug is on the rear of the pan, it doesn't make sense at all to have the car sloped downwards.
Generally, level is better. Jacking the front wheels with the drain plug removed will cause more oil to exit the drain as the car is tipped backwards.
As for the jack stand, I use a 2.5 ton hydraulic under my right front lift tab. I don't bother using the stand with that in place.
Old May 19, 2004 | 11:17 AM
eh!curaplus's Avatar
Team INSPIRE Canada
i havent changed the oil myself on my Tl yet, but with my Accord i use my ramps.
IMO it's safer and faster and you knew you got all the oil out, just gotta line them up and drive up the ramps. Never mind the price, safety comes first considering you'll have a car dangling over your head with just a reg. jack. ! I got them for about $50, for the heavy duty ones. *its a good investment to keep in mind!
Old May 19, 2004 | 12:44 PM
yield2s's Avatar
come on man. getting under a car with just a hydralic jack between you and death. SHHHHHHH1T!
Old May 19, 2004 | 01:33 PM
Bxscig's Avatar
squish!! Also if you are on a incline... I would think the jack or jack stands wont be as stable.
Old May 19, 2004 | 01:42 PM
so instead of the front of the car down, the front should face up at a slight angle?
also can anyone tell me if i do this with an slight angle like on ramps what direction does the oil shoot out? front, rear, left or right of the car?
Old May 19, 2004 | 01:43 PM
also i get it that ramps are a much safer way to do the change?
Old May 19, 2004 | 01:48 PM
i found these ramps, does anyone know of any others? with a higer lift? these any good?
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Old May 19, 2004 | 01:54 PM
beetzbat's Avatar
I changed my oil using running up ramp...nothing against regular jack but you need to be careful when applying togue opening up the drain washer...sometimes you shake car as well..
I got my ramp for 2 dollar on yard sale...it was pretty good and strong for TL (because it's a sedan, not sure for minivan or SUV)..so good luck..
I'd suggest you not to buy from retail...it's not worth the money...go get used ones.
Old May 19, 2004 | 01:57 PM
beetzbat's Avatar
Look like the same height as mine..however mine has a safety bump that will fit in your tire perfectly...it is just to make sure your car won't slip and rocking.
good luck
Old May 19, 2004 | 02:24 PM
Team INSPIRE Canada
my ramps are metal, with teeth on the bottom. the teeth suck because it destroys the asphalt on my driveway, but it's secure! just like beetzbat's ramps, it also has that safety bump plus it came in BLUE! they're also anti slip. Height on mine may be higher by 2-3 inches.
So yeah, you'll be alright just as long as you have your nose raised with a secure device! And dont forget to lay down some cardboard boxes cuz you cant avoid the oil drippings................. Good luck on your buy, and on the oil change itself.
Old May 19, 2004 | 03:39 PM
fsttyms1's Avatar
if the front of the car is pointed down you wont drain all the oil
sorry i forgot to take the rear while i was out there
HERE IS WHERE TO LIFT THE FRONT
Old May 19, 2004 | 04:26 PM
indoMFP's Avatar
What your problem is?
These are the kind that I got, but I bought mine for about $28 from Walmart. My only issue is that I don't scrape right now, but if I am thinking of getting the OEM ground kit and was wondering if they would scrape then.... I need to know how much lower the ground kit will make the car.....
Aside from that, I have had no problems with it.....
Old May 19, 2004 | 06:21 PM
tweedle99's Avatar
I have the same ramp and OEM kit, no scraping. Works great.
Old May 19, 2004 | 06:47 PM
Severin's Avatar
I also use wheel chucks in conjunction with the jack; it's not going anywhere. I basically put all my weight on the car and and rock it to test it before getting under. If I don't feel safe I place another hydraulic jack to back up the other. However, if I ever remove a tire I always use a jack stand for backup. I'm a small guy; I can fit under the car without the jack - if I could not I'd be worried.
PS: I've seen a neighbor long ago crushed to death under a '75 caddy doing suspension work in his driveway. It was quite common to see scissor jacks or bumper jacks slip and drop a car. However, it is far far less likely to occur with a 4-wheeled hydrolic jack and chucks on a level surface. In general you should always use as much protection as possible.
Old May 20, 2004 | 08:43 AM
DuckBlue's Avatar
its actually possible to change the oil without lifting the TL
if you bank your wheels to the right, you can reach in from the front passenger wheel well, and from there, you can reach both the drain pan, and the filter. i've changed my oil 3 times now, without lifting the car.
Old May 20, 2004 | 08:55 AM
Team INSPIRE Canada
[QUOTE=DuckBlue]its actually possible to change the oil without lifting the TL
if you bank your wheels to the right, you can reach in from the front passenger wheel well, QUOTE]
I hope you didn't mean to bank it on the SIDEWALK, cuz isn't that considered illegal parking? Just hope a cop doesn't drive down your street then, it could possible be a ticket! :smackhead
Old May 20, 2004 | 10:09 AM
fsttyms1's Avatar
[QUOTE=eh!curaplus]
no just turn it all the way to the righ slide your arm in the wheel well and you can reach the filter, lay on your back and you can reach the drain plug also
Old May 21, 2004 | 12:47 AM
how about the ramps with oem kit with comptech srpings? scrap?
Old May 21, 2004 | 09:06 AM
fsttyms1's Avatar
you wont make it up them with out building it up withalot of wood infront of the ramp. ive tried 3 different ramps and i can only get on 1 of them with the factory ride with out the front hitting and pushing. lowered and a kit will never make it on any
Old Jun 2, 2004 | 06:30 PM
will it fit with comptech drop without any kit? rhino 8000 series?
mada51589
Jan 9, 2025 04:40 PM
robm
Sep 18, 2015 07:53 AM
ja4lyfe
ZDX
Sep 17, 2015 09:10 AM
HydrasunGQ
Sep 14, 2015 10:14 PM
datadr
Sep 12, 2015 09:12 PM
