Oil change
Old Jan 6, 2006 | 11:12 AM
fsttyms1's Avatar
Oil change
Just changed the oil, 10k interval. 5 quarts went in 4.7 came out 198,300 miles
thats all just sharing
Old Jan 6, 2006 | 11:51 AM
VTEC11's Avatar
How did the oil look at 10k miles? What kind of filter are you using?
Old Jan 6, 2006 | 11:57 AM
ArN 2000 TL's Avatar
Moderator Alumnus
fsttyms1, any reason why every 10k? I have mine done every 3 but rarely do it myself due to good weather matching up with the weekends
Old Jan 6, 2006 | 12:16 PM
RickRoush03's Avatar
RickRoush03
3k has been shown to be "over doing it", even with dino oil, you could go every 5k miles, and most full synthetics about 10k. I use amsoil in both cars and its rated at 25k per change based on replacing the oil filter at ever 12.5k. On my bike, i go about 5k with full synthetic amsoil.
Old Jan 6, 2006 | 12:17 PM
samkws's Avatar
Comptech Freak
i am using honda OEM filter, so i am changing at 50k miles, even i am using synthetic
Old Jan 6, 2006 | 12:19 PM
samkws's Avatar
Comptech Freak
dino oil is not good to last 5k miles, they start to oxidizing after 2.5k miles
it's not that u cannot drive, but u can feel the performance has decreased
Old Jan 6, 2006 | 12:29 PM
SK2003TypeS's Avatar
What did you have in there ? And what did you just put in ?....the Mobil 1 Extended with the yellow cap ?
Old Jan 6, 2006 | 01:47 PM
fsttyms1's Avatar
Doesnt matter how it looks. Looks doesnt mean any thing (unless you areseeing moisture and green in it from antifreeze)
If it didnt turn dark in color id be worried that the oil wasnt doing its job. Ive been using fram extended gaurd filters for the life of teh car
I do 10-15k intervals because 3k is a waste and continues to be needllessly pounded into our heads by oil companies. Honda themselves recomends 7500 intervals for normal driving (which is what 99% of this board does)
If the guys building the engine rate it for 7500 why not listen to them over the oil companies and there 3k iterval crap? I think honda knows more by their engine testing and what their engine does to the oil
Mobil1 5w30 extended and put in the same stuff in
Old Jan 6, 2006 | 05:58 PM
russianDude's Avatar
I also use Mobil 1, used Mobil1 Extended once, but I am not going to use it anymore.
Its not GF-4 compliant, but regular Mobil 1 is GF-4 compliant.
GF-4 supposed to be more fuel efficent, but who the hell knows by how much ( 0.00000001 % ? )
I usually go 6000-7000 K miles on it, and the only reason is that I drive 10K miles a year.... otherwise I would do 10K miles just like you. don't want to have too much moisture build up. I use M1 oil filter.
Well, I agree with you, but there is a different theory that holds some water.
Those companies don't want you to drive your car forever, they want you to buy a new one
Old Jan 6, 2006 | 06:02 PM
As a side note: Honda engines are excellent and very durable.
Those engines can take abuse and still give you 200K miles.....
Now transmission is a different story
Old Jan 6, 2006 | 07:05 PM
ou sig's Avatar
Boomer SOONER
I change mine every 7-8k miles, just when I have time to get to. Im sure I could go longer (obviously), but after about 6 months, I kinda just want to do it. I use Mobil 1 5w30 synthetic with the Mobil 1 filter. I have never had any leak or problem yet, and I will do the same from now on. I change my wife's car at 4-5k miles because she only gets dyno oil ('97 mustang...)
Old Jan 6, 2006 | 09:21 PM
RickRoush03
Let me throw this at you, why did MOBIL 1 all of a sudden come out with 5k, 7.5k, 15k? Its the same damn oil as before, just relabeled b/c: 1. Amsoil proved their stuff was far superior to Mobil and you could go anywhere from 7500 - 25k or even 100k for semi's on Amsoil oil 2: Amsoil proved that oil is changed to often before its protection is actually used up, yes you can go 5k with dino oil, what do you think honda puts in at the dealership, or at least sell on the shelf, its not full sythetic and they recommend per the manual i think 7,500 miles.
Unless you run your engine at 5k - redline all day long, which no one on this board does with an acura or any TL out there for that matter, then noone needs to change their oil every 3k unless they are driving through a dust cloud all the time. My g/f's aunt use to work for Mobil and now works for Chevron, said the same thing i just stated above and below. Even said how people are so scared to switch to full synthetic b/c its soo thin it will cause leaks, umm, bs, a 5W-30 or a 5W-20 is the same weight per dino to semi to full synthetic, its the compound and construction of the molecules that makes up the oil, and full synthetic has perfectly lined up molecules and a whole other bunch of crap. Really, it comes down to the filter, a crappy filter will do you more harm than letting the oil go at longer intervals. Here, take a gander at this online article: http://motorcycleinfo.calsci.com/FilterXRef.html
Old Jan 7, 2006 | 04:41 AM
MikePA's Avatar
Right, you can 'feel' when your oil needs changed? I don't think so.
Old Jan 7, 2006 | 07:15 AM
Bxscig's Avatar
Anyone think New York City driving is considered harsh conditions to warrany a 3k mile oil change???
It is probably no where as bad as even Westchester, NY or NJ or even Long Island, NY...
Old Jan 7, 2006 | 02:45 PM
fsttyms1's Avatar
No
Old Jan 7, 2006 | 07:32 PM
Mr Hyde's Avatar
Thats just stupid. Any quality dino oil can do 5k in the harshest conditions. Here do some reading, and check out the oil analyses.
www.bobistheoilguy.com
The only people pushing 3k changes are the guys charging for them, and the ones selling the oil. If you want to waste your money, go for it, but you are getting no benefit from it.
Old Jan 8, 2006 | 04:04 PM
samkws's Avatar
Comptech Freak
yes, they can do 5k miles, but most ppl would not want to risk the costly repair of the engine instead
in the canadian honda/acura owner manual it's scheduled to change at 3750 miles instead of 6500miles due to the sereve weather in canada
b4 i switched to syn, i still get my oil changed at around 4-5k miles, now with amsoil/motul, i still changed at 5k, but i can feel that the oil can last much longer than that
Old Jan 8, 2006 | 04:09 PM
samkws's Avatar
Comptech Freak
after 4k miles with dino oil, actually the car is slower than when it's new
but synthetic still performs well
Old Jan 8, 2006 | 09:41 PM
SwampGas's Avatar
/etc/car
I change the oil as often as possible so the cutey neighbor across the street thinks I'm a big bad car guy instead of a nerd. I even beat the hell out of old rotors with a hammer to make noise. Maybe she looked and saw me and now is in love
Old Jan 8, 2006 | 10:14 PM
jcbzhnsr's Avatar
anyone heard anything good about bg44 synthetic? Just got a change done this morning, wondering what to expect as far as life? OEM replacement filter from dealership as well...
Old Jan 9, 2006 | 08:20 PM
Mr Hyde's Avatar
What risk?? The oil is safe for 5k easy like I said.
You can feel it?
Thanks, but I'll stick with the oil analyses, and info from guys with real knowledge on the topic at the link i posted. You should really check it out. Theres alot of good info on there.
Old Jan 10, 2006 | 07:37 AM
fla-tls's Avatar
On the way!
WOW - 50k - now that's an extended drain interval! j/k
mada51589
Jan 9, 2025 04:40 PM
robm
Sep 18, 2015 07:53 AM
ja4lyfe
ZDX
Sep 17, 2015 09:10 AM
HydrasunGQ
Sep 14, 2015 10:14 PM
datadr
Sep 12, 2015 09:12 PM
