Off the wall, but is it possible?
I've got a 2003 TL with 276k on the clock, and want the manual transmission.
I was thinking a k20 or k24 swap, maybe even an f or H series. I know there's the j32 cls swap, but I was just thinking. (no I am not a teenager obsessed with Honda 4 cylinders, this is a legit question)
I figure since our cars are built on an accord frame, an f23 should mat right up, and then building it beyond that. Just curious as to what you guys think.
^you'd have to boost both to get that power.
but it would be easier to boost the current engine instead of replacing it with a K24.
because the TL's only came in J32 variants, we dont even know if the 4 cylinder will mount up.
im sure there are aftermarket companies that sell fabricated mounts for this specific application, however; it just sounds like TOOOOOOOOOO MUCH FUCKING WORK, when you can just boost the J32 already in the car.
As quoted from K20a.org:
""400 whp n/a can cost over 25,000 dollars and it will not be street friendly, At All. and you would be running race gas all the time.""
I bet yah even with that kind of power the K24 will not be doing the Torque of a Stock J35... POWER TO WEIGHT RATIO Comes to mind here.
The J Series will pull harder and give you better results than any K Series Engine... This is a TL btw, Not a Civic.
A K is too new to make any sort of sense to swap in, as well. There is one 6th-gen Accord guy that swapped in a K. Lot of custom work. H-swaps are the most popular 4-cylinder swap, and considering the similarities with the 2nd-gen TL I would assume an H22 or something would be... the least illogical choice.
Swapping in a 4cyl would be very easy. The TL is an accord afterall. The accord came in manual and a 4cyl. Can it be done? Sure, but the question is why? You could drop in a CLS-6 trans and a J35a3 and throw a turbo on it running low boost and make more torque and hp than a k swap for much less money
J series is a significantly cheaper route, and with the weight of the car you will want that torque.
K series would definitely be a unique build but an expensive one at that, the only K I would do would be the K24 since it's already in a bigger chassis such as the TSX.
F20/F22 would be A LOT of work especially with it being RWD.
H, no. IDK anyone that does H swaps anymore. Really old tech right there.
spoiler900
Sep 10, 2015 01:06 PM
