Odd charging system behavior
Old Dec 22, 2022 | 09:01 PM
thender's Avatar
Greetings.
My car is a 2002 TL base model. 220k miles. I'm the original owner.
I have a voltmeter that goes into the cigar lighter so I can monitor system voltage while driving.
Most of the time it shows ~14.3V, which seems normal to me.
To be clear, it indicates ~14.3V on the highway, and also when idling at stoplights.
Sometimes, though, it drops to ~12.6 volts (battery voltage). This does NOT seem normal.
It shows the low voltage both while idling and also while driving.
Usually it will drop to the ~12.6V, stay there for a minute or two, then recover to 14.3V. It is toggling between those two states; it does not dwell at any intermediate voltages.
I do not get any failure lights on the dashboard when this happens.
Does this indicate a failing alternator? Or some other fault?
I'm the original owner and the car has been well maintained. I have not had any electrical or charging system issues.
I've made a cursory look for loose connections at/near the alternator but found nothing unusual.
Any thoughts appreciated!
mk5
3G RLX (2013+)
Aug 10, 2022 12:31 PM
silverstreaktsx
Jan 21, 2019 06:54 AM
RL09
May 23, 2016 05:29 PM
KayBee1
Oct 1, 2009 03:22 PM
red99cl2.3
Oct 7, 2003 11:25 AM
