Notice something w/ Nav
Sippy Cup (x2)
I recently took a trip up to Connecticut to visit some family and I noticed that sometimes my Nav screen would change colors. It had some purple in it and the clock turned red. I wasn't even able to see the time. Has this happened to anyone else or do you know what it could be? I think it may be when I have no signal for my nav but I am not sure.
did it happen when you turned on the headlights, i know mines changes color as it changes from day to night, which is when i switch on the headlights... maybe?
Sippy Cup (x2)
That wasn't it. The colors actually changed. It wasn't just a dimming, the color of the numbers on the clock changed from yellow to red and teh parts that are normally blue were purple. It was kind of weird...not sure why it did it though.
www.seattlewhips.com
this is typical w/ LCD screens when the ribbon cable is bad or something has a bad contact. In this case perhaps the soldier point(s) where the ribbon cable connects is bad. Please note that i am assuming it is a ribbon cable since i have never taken my navi apart... most LCD screens like laptops and such use ribbon cables of some kind, so that is my diagnosis.
Warranty should cover it. if you don't have a warranty, you could probably take it apart and just examine the soldier points to the actual LCD screen. i would just press it in places to see if you can recreate the problem. thats half the battle right there.
Sippy Cup (x2)
Originally Posted by vidhartha
no, my colors literally change also when i turn on the headlights, the colors that are normally tan are gray, all the colors are changed.
I think I will try to recreate the problem before I take it apart like you suggested. It's only happened when I took that trip and since I've been back, hasn't happened again. Thanks for the info guys.
CheeseyPoofs McNut
10-11-2015 11:25 AM
iesu3423
10-06-2015 06:54 PM
Rocktman1
09-19-2015 05:58 PM
andysinnh
09-05-2015 11:38 PM
