No gear indicator on digital displace when in SS mode??
Hello everyone
On my 02 tl-s has no gear indicator when I'm in SS mode, D5 light stayed on when I'm in SS mode and I also noticed that when I first turn the key to I position or II position they D5 light came on with the P light for a few second and turned off, the P light remain on. Need help please
Okay - then it isn't your circuit board behind the lcd panel. They are known to go out and require replacement (mine is intermittent).
Your shift selector might be faulty. There's another member who posted recently about it. He ended up having to replace his. Look for 1st hold switch (I think) to find the thread. It's in the last 2-3 weeks, maybe 4.
Chojun
Are you talking about this link right here?
https://acurazine.com/forums/second-...-p1710-938420/
Replaced the whole shift selector or just the bracket detent?
Chojun
Took the shift selector off and disconnected all the wires from the shift selector and the D5 light still on for a few seconds with the P light. Next step I might need to take the neutral safety switch out and check the connnection and clean out the switch.
Mr.Helpful Diagram
D5 light on for a few seconds is normal.
Have you tried shifting in SS mode ? if so does it shift.
When i'm in SS mode car shift normal thru all 5 gears, D5 stayed on even when I'm in SS mode. I did noticed on my outside temp display is dimmer than my odometer. Do you think possible the print panel (reg) the little circuit board in the dash might be bad and causing the SS gear indicator not turning on and half the left side of the temp/odometer dimmer than regular?
Mr.Helpful Diagram
It could be the dash, Try giving it a gentle whack while in SS mode to see if it lights up intermittently.
The temp part is a regular bulb that can be replaced.
Likely so. There's a DIY on here on how to replace it. It's a bit labor intensive because you need to remove the gauge cluster. So while you have that off I'd follow some other DIYs like changing out from bulbs to LEDs.
The part I think is around ~$50 if I remember correctly.
RxWorld
06-05-2016 08:11 AM
diamondmit
12-16-2015 01:58 PM
MayorMcCheese
12-15-2015 10:19 PM
Dclcd922
12-09-2015 05:37 PM
