NO AC or Heater
:( Harminder Is Lost In
NO AC or Heater
well i need some help again, will someone please help me or give me some ideas. After class today when i started up my car i hit the on button on the ac, but nothing, no air, no fan sound nothing. Tried the heater and had the same problem and it was working perfectly last night. Any one have ideas? i see teh temp and everything lights up, but it just doesnt come on.
Originally Posted by myTaLizaS3.2
maybe your fuse popped?
ive checked out the fuses, they are good, and one thing i must correct myself on i just noticed the radiator fan does come on but not as fast as usual.
H there, I had the similar problem with our 2000 acura tl. Ac/heater did not blow any air, and in fact it was the ac heater blower motor. Part is not to expensive total was around $200 with labor(about 3/4 was labor). Good luck
FINALLY GOT IT, and saved 150 dollars while at it damn dealers wanted 150 so what i did was remove the motor and ran two wires from battery and it worked, tested out the harness and it worked, but when i plug in the harness all the way for some reason it does not work so i left it out a little and it worked. Called around and found out harness is 20 bucks and would have to be ordered, so jumped online and found for 6 bucks and ordered it thanks for all your help.
harminder:
I'm having the same problem with my 99 TL (with NAVI)
Motor checks out, fuse is OK.
A neighborhood mechanic (who is very good) said I might have to return it to the dealer 'cause he suspects a "computer problem".
However, when you mentioned the "harness", are you referring to the 2 wire white plug that attaches to the front of the blower motor?
I'm a musician, not a mechanic, so if this question seems sophomoric, my apologies!
=buzz=
=buzz=
To All:
Found a post this morning, and got after my AC blower motor problem today.
https://acurazine.com/forums/showthr...ht=screwdriver
Went to Acura and spent 48.00 for the new "transistor" assembly (the secondary cable that attaches to the blower motor)
Currently working fine!
Thanks to all and thanks for this forum.
=buzz=
=buzz=
Biggie_B
02-26-2017 11:14 AM
