No. 56 40A fuse location
Old May 29, 2018 | 07:45 PM
Zeroskillet's Avatar
I can't seem to locate this fuse mentioned in title. Does anyone have a diagram of all the fuses numbered for a 1999 TL?
Old May 29, 2018 | 09:49 PM
Iggy's Avatar
What's the fuse for?
Old May 29, 2018 | 10:45 PM
01acls's Avatar
#17 engine fuse box.
Old May 30, 2018 | 06:19 PM
It’s to troubleshoot the AC blower. Sorry I’m full idiot..which one is #17
Old May 30, 2018 | 06:48 PM
01acls's Avatar
Heater Motor
Check the harness to the blower or the blower transistor.
Old May 30, 2018 | 07:00 PM
Thank you sir!
Old May 31, 2018 | 06:17 PM
Originally Posted by 01acls
Heater Motor
I checked the fuses and seem good, switched them out. I pulled of the blower motor connector (closest to door) and it visually looked good.
Now let let me run the “symptoms” by you and you tell me it might be the blower resistor or not.
I ran the diagnostic self test on the AC unit and it returns an N code which indicates a problem with the blower motor.
The compressor only turns on once when initially setting the AC and then turns off after 3 seconds...won’t turn on again unless I turn off car and turn back on again. Now on the inside the blower does turn on so nothing comes from vents.
Old May 31, 2018 | 08:38 PM
01acls's Avatar
Be sure to check the wiring too not just the connector.
The transistor is a real possibility, remove it for inspection.
Old May 31, 2018 | 09:10 PM
Cool beans! Will do
Old May 31, 2018 | 10:01 PM
Station's Avatar
Shot in the dark but could it be your system needs to be recharged? The compressor on my wife's jeep would turn on then off and wouldn't stay on. A trip to autozone for some r134a and it fixed the issue.
know610
Jan 21, 2017 05:21 PM
Thomasv
Jan 6, 2010 09:45 AM
Lore
Nov 19, 2004 06:25 PM
