2000 Acura 3.2 TL transmission jerk from 1st to 2nd
Old 06-27-2014, 02:48 AM
whatzupdudes7's Avatar
My acura jerks when shifting from 1st to 2nd gear. I have replaced the transmission about 1 yr ago when it blew out. What is the best thing to do right now? Transmission flush? I added more transmission fluid to make sure its not low in fluid but it did not solve the problem.
Any tips are rly appreciated thanks
Old 06-27-2014, 07:42 AM
CLtotheTL32's Avatar
Received 9,495 Likes on 6,167 Posts
My CL had the same symptom about a week before the transmission had to be replaced. Did you get a warranty when you replaced yours a year ago? When was the last time you totally drained the fluid and refilled?
Old 06-27-2014, 08:07 AM
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
Moving to 2nd gen forum.
Sadly this is one of he symptoms of a failng trans.
You can certainly try a flush which may extend the life a bit.
Old 06-27-2014, 09:00 AM
rockstar143's Avatar
Received 19,916 Likes on 14,458 Posts
Pressure switches don't make a difference? Damn, I hope it's not on it's way out.
Old 06-27-2014, 09:27 AM
juniorbean's Avatar
Received 1,760 Likes on 1,046 Posts
Sounds like the same thing that happened before my 2nd tranny died on me. I'd make an appt with your dealer ASAP...
Old 06-27-2014, 09:30 AM
Old 06-27-2014, 09:38 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
STOP!!!!
go back and ck fluid level per book method
adding some may have put it over= which is really bad!
Did you use Honda dw1 atf?
its possible you have a few problems, dirty solenoids, wrong fluid since rebuild, level incorrect, front or other motor mount broken
Ck those before deciding its toast
after cking fluid level again, call the shop who did the trans and take it by for inspection and test drive
Old 06-27-2014, 09:39 AM
:stop:
Old 06-27-2014, 10:29 AM
:stop:
Hammer time!
Old 06-27-2014, 11:23 AM
_
AZuser's Avatar
Received 3,097 Likes on 1,867 Posts
Try a complete flush with DW1
:stop:
Hammer time!
Old 06-27-2014, 02:04 PM
01tl4tl's Avatar
to be clear- we use the word flush to mean the manual drain and refill of trans fluid 3 times with 3 qts each time, with 5 minute drive between drainings using each gear up and down
see owner book for details- origianly used in case Dextron atf was added to the fluid- any at all will kill our trans
do NOT use a machine- they don't use Honda dw1 the only fluid you should let near your TL, especially at this point
a 3 oz sample of the atf sent to blackstone labs with 20 bucks will get a mass spectrograph inspection and interpretation by an actual HUMAN! who details what particulates have been found in what quantities- brass means one thing, other materials indicate the dreaded clutch wear, something else from gear wear etc
good news bad news or indifferent- the fluid tells all!
Old 06-27-2014, 07:11 PM
3.2TLc's Avatar
Replaced tranny a year ago, now jerking 1>2 shift
Welcome Whatzupdudes7 !!!
Tell us more about things like the tranny fluid condition, type fluid in it, if rebuilt and warrantied.
How many miles on it ? Have the mounts been checked ? Any CEL codes-flashing D5 ? Help us help ya better !
Ya may wanna just take it back to the shop where the last tranny was replaced.
Old 06-28-2014, 11:07 AM
Mr.Helpful Diagram
ErickUa5's Avatar
Theres a ground cable often forgotten by transmission shops on the 2000 and up. Just under the intake tube and brown in color fastened to the bracket and on the body.
It can cause some shifting issues.
01tl4tl (06-28-2014)
Old 06-28-2014, 06:13 PM
01tl4tl's Avatar
any missing or loose or crudded up ground connections will mess with many systems of the car
Good call Erick!
ErickUa5 (06-28-2014)
Old 06-29-2014, 12:44 AM
Gil'sUA5's Avatar
This happens to me too and my tranny was rebuilt about 6 months ago and i have brand new engine mounts so if anybody tells you its the mounts that is FALSE information. Oh and when my was rebuilt they used DW1 also. The Transmission shop that rebuilt my transmission (they've been in the business for 50 years and work on mostly japanese cars) said that its just part of the shitty characteristics of the 2nd Gen TL trans. That explanation makes sense to me to a point but sometimes mine jerks SO BAD from 1st to 2nd that i feel like it just can't be normal.
Old 06-29-2014, 08:07 AM
4th Gear
Moepaye's Avatar
How do starting system work on a 03 Acura tl type s??
Old 06-29-2014, 08:13 AM
4th Gear
Moepaye's Avatar
How do 03 Acura tl type s starting system works. How do power flow from the battery?? To ignition switch, starter solenoid, under hood fuse, stater relay, multiple control unit, im not sure please help.
Old 06-29-2014, 09:36 AM
01tl4tl's Avatar
even recent or brand new mounts have failed,a recent prob ziner had- new front leaked vac under testing before install
Moepaye
this is a thread about trans shifting problem
Do you have a general knowledge problem with starter system, or do you need help tracking a no start problem?
Ck the main thread area and sub section Problems and Fixes thread titles for your problem, if the SEARCH feature doesn't find you help then start a new thread in this main area
Old 06-29-2014, 10:28 AM
3.2TLc's Avatar
Thumbs down fresh rebuild has bad 1>2 jerk shifting.....
and sometimes mine jerks SO BAD from 1st to 2nd that i feel like it just can't be normal.
....... Yeah, rebuilding the original tranny is at most only a temporary band-aid fix.
For the same or less money, it makes more sense to install the "AV6" for better durability and value.
Old 06-30-2014, 11:25 PM
Gil'sUA5's Avatar
Moepaye
I have the XLR8 mounts and the mounts look perfect so i know for a fact its not my mounts.
Old 06-30-2014, 11:30 PM
Gil'sUA5's Avatar
very true but at the time i knew nothing about the AV6 trans swap. After paying $1000 for the rebuilt it isn't worth me doing the swap now obviously so i'll just put up with the jerking and ride it out, i hate when ppl say that your trans is on its way out when somebody mentions the jerking which is also false information. There is absolutely NOTHING wrong with my transmission its just the horrible way that they were designed, the jerking is also more noticeable while the car is cold.
Old 07-01-2014, 08:32 AM
3.2TLc's Avatar
Could possibly be a restriction in the fluid's flow or a faulty solenoid ?
PS: Under your Avatar, it states your join date as Mar, 2010. The "AV6" donor replacement option has been documented within this forum before ya had it replaced 6 months ago, so the information was readily available.
Old 07-01-2014, 08:51 PM
Gil'sUA5's Avatar
i Know the information was available but I'm not consistently active on the forum enough to have searched it before doing the rebuild. Im gonna buy brand new pressure switches to see if that does anything which i doubt but i know the switches that were put on the trans when it was rebuilt weren't brand new so maybe that might help?
Old 07-01-2014, 11:51 PM
1999 4at
skwidstyle2's Avatar
broken clutch control solenoid can cause your tranny to do a few weird things ... i would check it out/have it checked. if its faulty they are about $85 on ebay
Old 06-02-2018, 08:31 PM
7th Gear
Rickcanada's Avatar
Tranny
what is an AV6?
Old 06-03-2018, 08:56 AM
Iggy's Avatar
Originally Posted by Rickcanada
what is an AV6?
run a search on AV6
NwTSXmt
3G MDX (2014-2020)
40
12-01-2015 12:01 PM
kmarqueling
10-03-2015 01:14 AM
Skirmich
09-15-2015 06:41 PM
Mike Bertram
09-10-2015 09:27 AM
asahrts
09-04-2015 05:55 PM
Quick Reply: 2000 Acura 3.2 TL transmission jerk from 1st to 2nd
