Temperature gauge faulty
Old May 27, 2018 | 07:39 PM
Acuratl3535's Avatar
I’m having a issue with my temp gauge. When I start the car the temp gauge starts below/at the C on the gauge and gradually climbs up s little below the half way mark. But the other day my car over heated and was spitting out anti freeze out of the reserve tank and the gauge never went up. I was thinking that it was my thermostat would be my problem so I bought one and was going to install tomorrow but after reading g some threads I’m thinking it may be the temp sensor or gauge itself. Any help would be greatly appricated. Thank you
Old May 28, 2018 | 11:23 AM
frankjnjr's Avatar
Which year, model, and how many miles. Have you pressure tested the cooling system, for leaks? Temperature sensor, and temp gauge failures are somewhat rare. If, the engine coolant was low, initially, the sensor, and gauge MAY NOT, work properly.
Old May 28, 2018 | 12:01 PM
It’s a 2003 Acura TL with 162,000 miles. I have not pressure tested the cooling system. I’m going to see if I get it tested for leaks tomorrow. It could’ve been low on coolant. Since I refilled it, I haven’t lost any.
Old May 28, 2018 | 12:33 PM
frankjnjr's Avatar
Like i said, temp. sensor, and gauge issues on our cars. are unusual. My 03 TLS has 239K. I, nor have several acquaintances,driving 2G TLs, for years, experienced a sensor, or gauge problem! When you have the system checked, make sure to ask your Tech, to BLEED the system PROPERLY, in accordance with the Acura manual! Air in the system, on our cars, may not only affect the gauge reading, it may also affect the engine idle..
Old Jun 2, 2018 | 02:36 PM
Does the 2003 Acura TL have a bleeder screw by thermostat? Also when the car is at engine temp should the outgoing hose from the rad be extremely hot? Mine is so hot I can barely keep my hand on it?
Old Jun 2, 2018 | 04:11 PM
Karanx7's Avatar
Unregistered Member
Bleeder screw is on the back of the block. The hose would obviously be pretty hot...
Old Jun 2, 2018 | 04:48 PM
01acls's Avatar
There is no coolant bleeder screw on the TL. That is the engine block coolant drain plug. Bleeder screws are usually on top or near the top of and engine.
Old Jun 3, 2018 | 01:03 AM
So today I was able to bleed the system. Wasn’t much air in there. My gauge stays below the middle line on temp gauge. Not sure if it’s suppose to be at the middle line or it’s ok to be below? I’m going to be checking the coolant temp sensor tomorrow and make sure I installed the thermostat with the pin up. I’ll post what I find tomorrow
Old Jun 3, 2018 | 06:47 AM
frankjnjr's Avatar
Mine. normally rests one, or two lines below mid-range, depending on ambient. Used to run one or two lines, above mid-range, until I had the a/c condenser, and radiator fins, professionally cleaned.
Old Jun 3, 2018 | 03:27 PM
Karanx7's Avatar
Unregistered Member
Ah, that's right. It's just a drain plug.
A tick below half way is normal.
El-Baz
1G RL (1996-2004)
42
Jun 19, 2017 08:28 PM
Carbon Legend
Nov 25, 2016 01:50 AM
Umair Raza Khan
Nov 8, 2016 04:00 AM
fsttyms1
Jan 30, 2009 06:43 PM
Thomasio
Sep 11, 2002 12:44 PM
