New wheels
Considering you are not lowered:
17" x 7.5-8 Stock sized = best of both worlds.
18" x 7.5-8.5 Sized = tires get a little bit more expensive, Some fitment needed (Offset Needed), Some Fender Roll Helps.
19" x 8-9 Sized = tires get even more expensive, Exact fitment needed (Offset Exact), Fender Pull, Fender Roll, Etc,etc.
20" GTFOH!
If you are lowered things get even more complicated.
20" GTFOH!
^ I edited my post, I added widths.
19" With some crazy fitting and fender pulls/rolls they do: But expect camber kits, A-Arms and so on = $$$
Also 19" start to look hideous on the TL.. You need the right wheel model to pull it off.
8 would be the sensitive decision.
8.5 would be the maximum I've seen, but that guy really fight it to pull it off.
9? I know it isn't unheard off but I personally haven't seen them.
I find that 18x8.5 +35 on 225/40/18 tires make a great set up for a daily. You would still need to roll the fenders and cut the bumper tabs if lowered. If you do 19x8.5 +35 on 225/35/19 tires, you need to watch out for potholes at highway speeds, your rims with bend (personal experience). I would stick with 18" if you plan to actually drive the car.
19x8.5 +35, 225/35/19. 18x8" +35 will make your life a lot easier. 8.5" will definitely require modification but will be more flush with the fenders.
JByron
01-08-2016 09:49 PM
