New Guy with a TL
Old Feb 22, 2010 | 06:10 AM
laziebun's Avatar
New Guy with a TL
Well i just bought a used 2002 TL type S with 167,000 miles on it and was wondering what you guy think i need to do first to keep it running right? Are there certain things that fail that i should be looking for etc....?
Old Feb 22, 2010 | 09:45 AM
Rajca's Avatar
wham bam thank you ma'am
when was the trans replaced? save money for that 3-4k or buy a used 04-06 tl trans or 04 odyssey trans, those last a whole lot longer than ours and have a shop install it.2k max installed
105k service? check the breaks, suspension, air filters, valve adj. (but u can do that when u do teh 105k), run some seafoam in the oil, gas and intake, change the oil, how are the tires?
Old Feb 22, 2010 | 11:21 AM
01tl4tl's Avatar
be sure the timing belt and water pump were done at 105, if not do those NOW
Have a read thru the thread titles for advice on what to do on your new baby
register with acura as the new owner and ask for a history of warranty work done or open recalls
1-800-382-2238x5
Old Feb 22, 2010 | 11:56 AM
laziebun's Avatar
The last Trans was replace at a local dealer at 115,000 and it now has 167,000 miles. so the 04-06 TL trans will button right up?
Old Feb 22, 2010 | 11:59 AM
gold2003tl (90)'s Avatar
2003 TL-p
yes, i think all you need to do is switch out the solenoid values.
how is the replacement tranny holding up, any slipping?
Old Feb 22, 2010 | 12:38 PM
Rajca's Avatar
just need to switch some sensors/solenoids and tap some holes in the trans. thats all. no fabrication required.
Old Feb 22, 2010 | 12:58 PM
laziebun's Avatar
I think it shifting fine no slipping or hard shifts. But the shop that did ALL the work needs the person name that was register when service was done to bring up info on exactly what was completed. So does anyone know how to go about getting names of previous owners??
On car-fax it says all schedule maintenance was completed for each of the schedule mile mark Acura recommended to bring in.
OculiAquilae
Nov 19, 2018 02:24 PM
funkbro2
Nov 17, 2015 10:23 PM
knight rider
Oct 1, 2015 10:29 AM
ja4lyfe
ZDX
Sep 17, 2015 09:10 AM
Nicho863
Sep 3, 2015 09:16 PM
