neuspeed strut bar help
got the neuspeed strut bar today and i am having some trouble installing it. the bar is about 3/4 of an inch to wide. has anyone else had this trouble. i read how austin bent his. how did you bend it what did you use etc etc.
just looking to see if there is something that i am missing cause i have been trying to force that f*cker on there for about 45 minutes.
I had the same problem...here is what you do:...place one side of the bar mounting area on the strut assembly bolts, then take a towel and wrap it around the other side where the bar attaches to the mounting area, slowly tap the bar where the towel is with a hammer until both sides are on, then bolt one side down completely and tighten, then tap again to make sure the bar is all the way on and bolt and tighten the other side, your finished...this is what the performance shop did to get the bar on my car...hope this helps.
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
