NEED OIL CHANGE! Whats the best oil for a 99TL?
#81
Originally Posted by Pure Adrenaline
That's my job.
yeah, that's a challenge...
![Run](https://acurazine.com/forums/images/smilies/run.gif)
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
![Ninja](https://acurazine.com/forums/images/smilies/ninja.gif)
#83
Originally Posted by brakejobhelp
Mobil I and Amsoil are regarded as a Group IV oil, some say they are mixed with group V oils, who knows...
Redline oil is a Group V oil Only...
downside: its so fucking expensive...
redline also uses the most moylbendium than any other oil, and the polyol ester base stocks are considered the best (and most expensive)
redline's friction (or lack thereof) has shown the highest increase in horsepower in engines (3%)
redline oil is like a high value sports car. not a lot of advertising, and no marketing saturation like other motor oils, and no care for market pricing... just high quality oil for those who can afford it...
<-- puts on flame suit
#84
Originally Posted by 99bluetlwtt
Amsoil cost as much as Redline. Where can I find redline?? Do they have Dyno prove that it help increase horses??? Cause I never believe Royal Purple increases torque. WTF Motor oil does not increase any horse power or torque. I thought the only thing great motor oil does is less wear and tear in our engines.
#85
:brakejob:
#86
:brakejob:
Originally Posted by optomos
Less wear=less friction/less friction=more power
#87
#88
Originally Posted by TLMugen
Cool, no problem.
I'm aware of these products and from the VOAs I've seen, they don't seem to have a lot of moly in them, "Moly" is just a name. They're excellent oils but if you're buying them thinking you're gettting a high moly oil, you're better off looking elsewhere.
I spike my M1 with, you guessed it, Mugen MT-105 moly additive (it's a MoDTC concentrate). I just add a portion of the bottle, only a couple mLs, and it boosts up the moly level nicely. Mobil 1 usually runs between 60 and 80 ppm moly, my last UOA of spiked M1 showed 501 ppm moly (I think Honda oil runs about 300 ppm Mo). An alternative moly additive to consider is Torco MPZ, which reportedly contains moly at over 7000 ppm so you only need a little to boost M1 (or other oils) past even Honda oil levels. I'm going to try MPZ in my next oil change.
I know there's probably no need to go this far with the additives since millions of Hondas do just fine without them but that's just my prerogative. I'm one of those old school moly people.
BTW - More and more oils are using higher amounts of moly these days (even Amsoil will probably using Mo in their oils). Previously, it wasn't used as much because of cost. Now, with the newer, tougher oil specs, Mo is making a comeback.
Sorry for the long post.
Besides, there is really no need to add more moly to your oil unless you're running an outdated oil. It is the OVERALL oil chemistry that is important, not just one particular additive (i.e. moly).
Michael
#89
The problem that I have with Amsoil is that it thickens out of grade due to oxidation. The only way to resolve this problem is to use Lube Control to control oxidation and maintain solvency. Otherwise, the oil will become a 40wt by 10K, which is unacceptable to me.
However, I'd like to note that Amsoil's Grp III XL 5w-20 does very well in 5w-20 apps and doesn't seem to thicken, it is one of the few Grp IIIs that do as well as the Group IV oils.
My vote goes to a good 20wt in this app, either Amsoil XL 5w-20 (pref.) or M1 5w-20.
Michael
Michael
#90
:brakejob:
Originally Posted by fsttyms1
how is that possible? teh computer regulates the rpm
unloaded about 610 rpm to about 640-660 (seems to depend on god knows what)
loaded about 700-730rpm to about 750-800rpm depending also on god knows what
i assume the idle is set to a range, not an exact number, similar to my d17 powered civic beater...
#91
![Smile](https://acurazine.com/forums/images/icons/icon7.gif)
just use M1, amsoil or redline!
mada51589
05-03-2022 08:54 PM
HydrasunGQ
09-14-2015 10:14 PM
