need help taken off door panel
u can get step-by-step master sheet instructions from crutchfield.com for like 5 bucks..They sent me 1 4 free when i ordered a wire harness for my alpine head unit. It was pretty much right on, and shows how to remove dash, and door panels.
there is a screw that holds that in, then you slide it forward just enough to pop it out. Then you pop the clip that holds the metal rod inplace. there is also a screw in the door handle (large hol from underneath) after than then all you do is start at the bottom and pull out on the door panel. Its just helpd on by clips. Get them undone and lift up to free from upper part of door
soupi
14
11-15-2015 11:15 AM
xsilverhawkx
09-28-2015 06:51 PM
