Need help with missing wires
Old Oct 27, 2008 | 01:44 PM
Rodrick25's Avatar
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Can someone tell me what these wires are for and where the missing wires goes.
It's a 03 TL-S
Old Oct 27, 2008 | 02:17 PM
jjashaa's Avatar
Avant Garde Wheels
thats for VTAK yo... lol
yea.. i don't kno.. useless post..
looks pretty bad.. you kno what happend?
Old Oct 27, 2008 | 02:20 PM
EL19's Avatar
looks like a sensor of some kind
Old Oct 27, 2008 | 03:43 PM
Rodrick25's Avatar
Car crashed I also saw rat poop under the hood. I don’t know if the rat bit it or is from the crash.
Old Oct 27, 2008 | 03:47 PM
Rajca's Avatar
wham bam thank you ma'am
i had a rat eat through my knock sensor wires, u got a check engine light on?
Old Oct 27, 2008 | 03:49 PM
Rajca's Avatar
do u have this wire? outlined in blue. also does the car hit the limiter
Old Oct 27, 2008 | 04:11 PM
Rodrick25's Avatar
[IMG][/IMG]
This?
Old Oct 27, 2008 | 04:26 PM
fsttyms1's Avatar
There are 2 wires in that area. 1 is for the TDC sensors and one si for a temp sensor for the motor. I cant tell in those pics which wires are actually damaged but it looks like the temp sensor wire???
Old Oct 27, 2008 | 05:05 PM
Rodrick25's Avatar
[IMG][/IMG]
How about this.
Old Oct 27, 2008 | 05:16 PM
Rodrick25's Avatar
Any tip on moving the power steering pump.
Old Oct 27, 2008 | 05:24 PM
Rodrick25's Avatar
What is TDC?
Old Oct 27, 2008 | 05:31 PM
Rajca's Avatar
top dead sensor, senses the when piston #1 is at top dead sensor
Old Oct 27, 2008 | 05:44 PM
AMGala's Avatar
Lamborghini Aventador FTW
top dead center, senses the when piston #1 is at top dead center
fixed
Old Oct 27, 2008 | 05:49 PM
Rajca's Avatar
top dead center
sry about that mistake
thx amgala, i was thinking about the sensor and thats what i wrote down
Old Oct 27, 2008 | 06:02 PM
fsttyms1's Avatar
Those arent the TDC wires. I cant tell what they are. but they are on the wrong side for that now that i look closer.
To remove the power steering pump there is the one in the pics that has the long bolt with a nut on it. Loosen that most of the way which will take the tension off the belt, there is a nut/bolt on the bottom side that needs to removed then remove the nut that holds that to teh PS Pump. then on the back side there is a bolt.
Old Oct 30, 2008 | 08:09 AM
Rodrick25's Avatar
[IMG][/IMG]
How about this one.
Old Oct 30, 2008 | 02:02 PM
phee's Avatar
I got the Shifts
turn on macro in your camera and take a close up pic of the chewed wires. macro will allow you to focus within an inch of the wires. ill take a pic of my engine for u
Old Oct 30, 2008 | 03:20 PM
fsttyms1's Avatar
I cant tell from there. The only wire i know of that is under the intake runners is a temp sensor. Either way there isnt a separate harness to buy. The whole engine harness is 1 unit.
Old Nov 6, 2008 | 07:22 PM
Rodrick25's Avatar
Is this better?
Old Nov 6, 2008 | 08:09 PM
Rajca's Avatar
do u have any check engine lights on?
Old Nov 6, 2008 | 08:47 PM
Rodrick25's Avatar
Yeah. And the fan is not coming on and the engine is searing
Old Nov 6, 2008 | 09:03 PM
Rajca's Avatar
whats the code? ill look at my car tomorrow to maybe see where the wires go and also look at some wiring diagrams, but a code would help alot.
Old Nov 7, 2008 | 09:49 AM
Rodrick25's Avatar
What code?
Old Nov 7, 2008 | 10:03 AM
5daddy13's Avatar
PNYXPRS
All vehicles manufactured since '96 are required to have an OBD II computer system. This computer monitors almost all vehicle systems. When there is an anomally in the sytem it will "throw" a code. There is a port under the driver's side dash that accepts a code reader that when plugged in will produce a readout with numbers. Those numbers translate in to the anomally the system is experiencing. Most parts stores will have the reader and many will attach the reader and download your codes at no cost to you. Once you have the codes we will be able to isolate what the problem is with your car. The code will probably help I.D. that missing wiring harness as well.
Old Nov 7, 2008 | 01:07 PM
fsttyms1's Avatar
Originally Posted by Rodrick25
Is this better?
Ok im going to ask this. What exactly are you looking for from us? You know what wire is damaged. there should be the matching wire cut somewhere near by. I posted earlier you cant "just" purchase the wire you need. all the wires on the engine are connected to 1 giant harness. You will have to try to attach what you have. You will probably have to remove the lower manifold runners to see or gain more access. If your car is running how without it it probably has something to do with a temp sensor or fan. DONT drive it if its not cooling properly unless you want to buy a new motor.
Old Nov 7, 2008 | 06:09 PM
Rodrick25's Avatar
what i really want to know is, what are these wires 4 and where do they go?
I cant find the matching wires.
Old Dec 5, 2008 | 07:11 AM
Rodrick25's Avatar
Did look to see where the wires go?
I think it may be part of the engine wire harness anyone have a diagram?
Old Dec 5, 2008 | 10:09 AM
Rajca's Avatar
theirs quiet a bit to to take off just to see where the wires go. do u have any codes?
Old Dec 5, 2008 | 10:46 AM
Rodrick25's Avatar
Can I get the code with the throttle body, the intake manifold and the P/S pump off.
Old Dec 5, 2008 | 10:57 AM
Rajca's Avatar
you will get many codes with all that off.
Old Dec 5, 2008 | 11:31 AM
Rodrick25's Avatar
Gess I'll start putting every thing back up.Let you know when I'm done and have the code .
Old Jan 12, 2009 | 07:19 AM
Rodrick25's Avatar
This one is number 2 in the pic. It goes under the intake (the thing with the 6 holes on top). I think it is the temp sensor.
[IMG][/IMG]
This one is number 1 in the pic.
I think the two connects together but don’t know how to cause one has 2 wires in side.
[IMG][/IMG]
[IMG][/IMG]
Old Jan 12, 2009 | 11:35 PM
Rajca's Avatar
next weekend im gonna be adjusting my valves and doing some work to my car, so ill take as many pics of the sensors and wires as i can, and were they go.
Old Jan 13, 2009 | 04:22 PM
Rodrick25's Avatar
Thanks.
tsx_boy
Dec 13, 2019 08:33 PM
gatrhumpy
19
Dec 31, 2015 04:22 PM
dainmezron
Oct 16, 2015 06:56 PM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
