Need an engine...
Old Oct 28, 2012 | 03:10 PM
illmat1k's Avatar
Thass Wassup!
Exclamation Need an engine...
Anyone know of any places in So Cal that sell used J32A2 engines?
I let mine overheat by accident when my radiator blew last month and now it runs like sh*t.
Also, does anyone have any suggestions on doing a rebuild?
Old Oct 28, 2012 | 04:00 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
Check car-part.com and select by location and put your zip code in
Old Oct 28, 2012 | 07:09 PM
Karanx7's Avatar
Unregistered Member
Would be cheaper to get a new engine than changing the head gasket.
Old Nov 4, 2012 | 02:20 AM
reaper101's Avatar
live fast or die slow
Theres a rebuilt one in Houston I just bought a tranny from the guy
Old Nov 4, 2012 | 02:52 AM
rush's Avatar
03 acura cl type s
get a mdx engine instead you wouldn't be mad + is its prob cheaper more pwr
Old Nov 4, 2012 | 03:42 AM
STONEColdAcurazineLegendZ's Avatar
you can check Craigslist adds for engines Only go to JDM engine suppliers its your best bet tl motors car range from 650+ from these kind of folks http://www.jdmenginescorp.com/engines/acura/ if you cant find a jdm warehouse you got to find ship it or salvage or etc
Old Nov 4, 2012 | 03:48 AM
They are right it is cheaper to get a new engine but its all what you want if you want to have to pull the motor or save the engine you got and see where its going to take you. In the name of the acura game if you break it you replace it with factory spec parts or better.
Old Nov 4, 2012 | 04:57 PM
01tl4tl's Avatar
a sever overheat does more than blow a head gasket
things like piston rings and bearings get too hot... and a few months later...
ck local auto dismantling and recycling (formerly junkyards)
they have a hotline system to other places- can find out who has what you need and get it sent to them or your door
the internet is the place to start. ebay has a biz with our tbelt kit with everything, for 200-250$ made by asaia? asahi? something like that--same name is on the stock part
do replace water pump -timing belt- all tensioners and belts, so you have it fresh and ready to go
Smart money would adjust the valves and clean egr system inside intake manifold before doing the install,,,while its all in easy reach
Old Nov 4, 2012 | 04:59 PM
01tl4tl's Avatar
new plugs and of course once running SEAFOAM!!
Old Nov 13, 2012 | 11:12 PM
illmat1k's Avatar
Thass Wassup!
Thanks for the all the input guys. I haven't found a replacement engine yet as they all have tons of miles on them. I was recommended by a mechanic that has apparently done swaps in the 2nd gen TL to do the J35A8 from the RL/07-08 TL-S.
What's your guys' input on this?
Old Nov 14, 2012 | 07:03 AM
fsttyms1's Avatar
Won't work with our trans/ecu.
Search outside of your area. Many places ship and its not that expensive.
Old Nov 14, 2012 | 03:55 PM
Originally Posted by fsttyms1
Won't work with our trans(Bell-housing is different)/ecu.
There are plenty of engines with low miles you just have to expand your search
Old Nov 14, 2012 | 09:20 PM
fsttyms1's Avatar
I picked up a 02 MDX 3.5 with like 50k miles for 350 bucks.
Old Nov 15, 2012 | 03:45 AM
damn I need to start looking again.
Old Nov 15, 2012 | 09:12 PM
DEPTLS's Avatar
Yeah, where do you see them so cheap? ive checked car_part.com but not for such a low price
Old Nov 15, 2012 | 09:21 PM
x2 I always check within 500 miles of me and none are that cheap I guess I need to expand the search.
Old Nov 16, 2012 | 06:53 AM
fsttyms1's Avatar
I found it on carpart. And fairly local to me too
Old Nov 16, 2012 | 08:31 AM
DEPTLS's Avatar
You got lucky... Play a scratch off...
Old Nov 17, 2012 | 08:49 PM
spydercatt's Avatar
Check this site out. Sure they can help you with an engine.
http://www.naganojapanese.com/
Old Nov 17, 2012 | 10:05 PM
^ those are a bit overpriced compared to what you can get of car-part.com
23109VC
23
Jul 24, 2008 06:51 PM
justinl401
Apr 25, 2008 01:25 AM
jungsoo726
Jan 27, 2008 01:45 PM
schummi
1G CL Problems & Fixes
Jan 16, 2008 03:12 PM
Nashua_Night_Hawk
Oct 13, 2002 12:03 PM
