Need a AEM CAI pic....im stuck installing
Old Sep 14, 2001 | 07:51 PM
AzNTL's Avatar
Question Need a AEM CAI pic....im stuck installing
im stucking installing the AEM CAI particarly on the second half of the tubing... i cant get the bypass vavle on right and which way the second tubing is facing where where to connect it to?? PLEASE HELp...
Thnx in advance
-An
Old Sep 14, 2001 | 08:15 PM
ArN 2000 TL's Avatar
Moderator Alumnus
Hope these help
Old Sep 14, 2001 | 08:16 PM
Moderator Alumnus
If you notice I do no have the bypas vlave but it goes right where the pipes connect...i think it replaces the rubber gasket
Old Sep 14, 2001 | 11:14 PM
AzNTL's Avatar
where does the bar that comes off of the lower pipe attach to?
Old Sep 14, 2001 | 11:33 PM
Moderator Alumnus
There are already drilled points...check this for install instructions. I used it so I know its good
http://www.acura-tl.com/faq.htm#1c
Old Sep 15, 2001 | 12:30 PM
Shyne's Avatar
Dude the bracket on the lower piece gave me so much problems I couldnt figure it out... I think the bypass valve messed that up for me, im gonna figure it out today when I clean my CAI...Ive been using mine for about 5 months now, and I havent had the lower part connected...By tha way, tha bypass valve will break so watch out!!!Shyne
Old Sep 15, 2001 | 12:48 PM
TLS RULZ's Avatar
more pics
ANnTL,
here are some pics I found from the CL forum. It should be pretty much the same. Hope they help.
http://wizardsworks.org/chod/acura/
Old Sep 15, 2001 | 06:24 PM
Nate's Avatar
I believe you must cut on of the pipes to get them to fit with the by-pass valve. I couldn't get it installed without cutting. Note that I decided to just run SRI for the meantime.
Old Sep 15, 2001 | 10:50 PM
AzNTL's Avatar
Thnx for the help guys but do i need to cut the pipe a little bit to install my bypass valve?
Old Sep 16, 2001 | 11:45 AM
wiggingboy's Avatar
i also have a question on installing the CAI. there is 2 lil hoses that was connect to the old air box that has fluid in it. what do i do with ?? do i run it back into the engine?? And shyne, did you just leave the second tube hanging without connecting it?? i couldnt figure out how it goes in also.
Old Sep 16, 2001 | 11:51 AM
AzNTL's Avatar
i just connected the tubes to the CAI and it works fine
Old Sep 17, 2001 | 01:33 AM
Nate's Avatar
Connect 'em together instead of them going into the stock air box. 99s run coolant to warm the air in extremely cold temperatures I believe.
BoricuaTL
Apr 8, 2016 01:08 PM
InFaMouSLink
Oct 27, 2015 06:51 PM
carz0159
Sep 20, 2015 06:11 PM
TxRzrBk
Sep 17, 2015 01:07 PM
Abe_Froman
Sep 16, 2015 01:27 PM
