Need advice on tranny question
Hey guys, it's been a while last time i've posted here.
I need you guys to help to decide what to do with my TL.
What happened:
- tranny gone, it's still drivable for short distance (was last year
- I got front right wheel accident, and it looks like CrossMember might need to be replaced. Still had to do the measurements (Does anyone has numbers, or i'll have to go to acura dealership?)
So i need you guys to tell me what would you do in my case?
Manual swap? or 08 TL AT swap?
I've put to much money and time to that car and i don't feel like selling it, coz i would never buy anything close to it for the money i'll get for it.
It is almost spring and time to decide what to do...
Thanks a lot (sad)
What happened:
Thanks a lot (sad)
any back probs/injuries, or current sporting activities that may lead to one?
do you want to add the constant use of hip and leg for clutch?
or do you like the choice of casual D5 or `modern style sport shift/paddle shift` effect with the auto trans?
are there weather considerations--snow ice etc,,where plodding along in an auto would be nice?
a body shop, or info probably online, for the spec measurements
body shop will have `the book` they use to know if/what things are bent
While a dealer often sends out body shop stuff to a different place,,not done by their own on-site department
Not really.
Also, let's assume - i would able to do the AT tranny swap myself, while MT swap i would need someone help.
I wonder how they fix the cars then!
call a place in the States ?
less parts and cutting involved with auto trans
just an ecu swap and whatever wiring goes with it--is my best guess
accord/oddy trans swappers--whats your info on this?
Do you also need to change the ecu to make the tranny work in the 2nd gen cars? If so, will the new ecu work with the original engine?
I know somebody out in nyc that would rebuild your tranny for 1200 but its way to far from you. He did 3 Tl's for me and all of them came out great and they also provide you with 6month warranty and if you want a longer warranty you have to pay extra 200.
these are all examples of 5 speed auto transmissions. No ecu swaps required. Everything would bolt up and most sensors with plug up. I had to change the range sensor switch and the bracket for the shifter had to be modified. Nothing else as far as i remember was required.
I saw few 07-08 AT trannys on sale around.
Any differences between models?
Accord transmission will miss LSD, right?
Don't wanna rebuild it :/ and yeah, my car probably won't make it there.
Chapter Leader (Southeast Region)
https://acurazine.com/forums/2g-cl-problems-fixes-70/another-solution-my-auto-cl-guys-758220/
https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/2nd-gen-tl-auto-transmission-alternatives-753294/
'06>'07 Accord V-6, 5 speed AT .....get a lower mileage tranny out of a car that hasn't been hit hard in the front. Best bang for the buck !!!
BobbyGraham388
10-22-2015 05:05 PM
