Navi Voice gone!
I think that warrants a trip to the dealer.
Have you installed any aftermarket stereo equipment that could have caused this?
Hopefully if ur still stock radio the dealer can fix painlessly for you
Originally posted by vperkins2
- Check/change Navi volume control... Does is make a "ding" when changed?
Hmmif your stereo still works and front speakers still do it sounds like a short. Try grounding the mute wire on the back of the 20 pin harness A on the Bose. Do it when the navi voice button is pressed . That will switch the signal to the navi untill the grounding is undone. That way you can see if maybe the mute lead from navi that sends a ground signal while navi voice is active, still works. I can tell you which pin exactly later tonight if you want to try it but you gotta take apart center console.
I already have an appoinment @ Brunswick Acura to have them look at it... the speakers still work.. I tried restarting the motor... but didn't remove the disc.. maybe I'll give that a try...
Thanks for all of the suggestions.
V.
Same thing just happened today. NAVI voice doesn't come on, just electrical noise like a badly tuned AM station. I get the button beeps, and temporary mute when the voice is supposed to come on, but no voice or 'dings'.
I also noticed that my OnStar isn't working either. Well, luckily I have an appointment at PAA tomorrow morning, so hopefully it's a quick resolution. I don't have any audio mods so I doubt they're going to hassle me about it. I'll post with the results. Kinda strange that this is happening to an '03 TL that's 2 months old!
ckNJ
ckNJ
are you referring to brunswick acura in NJ on route 18N? if so, how did you like their salespeople? i personally think they are all jerks and i would never get another acura from them.
ckNJ
ckNJ
It wasn't the fuse. Since it's a new car the guys over at PAA are ordering a new NAVI unit. I'm glad they're not trying to fix stuff that shouldn't be breaking so early in the first place. Nice to know that they're looking out for my best interests. Kudos...
What have you done to try and fix it? Here's a few things I was thinking of...
Good luck!
V.
Good luck!
V.
Most likely you have to check both front speakers. Fade control.
Originally posted by songoku
Why just drive side??
I guess I said "driver's side" because that's where I always hear the Navi voice come from. It was just a quick list of things to check -- I'm glad other folks added their .02 cents as well.V.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
TLguy42
Sep 26, 2015 11:27 AM
