Navi security
Old Sep 2, 2001 | 11:38 PM
bigman's Avatar
'Big Daddy Diggler'
Navi security
Is there any way to get the security code for the navi, or is there a universal code or something. My 99 has a code in it but i dont know what it is.
Old Sep 2, 2001 | 11:55 PM
Acura3200's Avatar
Re: Navi security
call the dealer with the SERIAL NUMBER of the NAV UNIT and they will give you the code
Old Sep 3, 2001 | 12:17 AM
bebber's Avatar
Say, I've disconnected by battery and reconnected it. My radio displays "code" and requires that I enter in a code, but my navi doesn't do that and it works fine. Is the anti-theft feature of my Navi malfunctioning?
Old Sep 3, 2001 | 09:25 AM
BarryH's Avatar
I think the Navi has a back-up battery so that it doesn't lose the settings and addresses stored in it - kind of like a Palm or laptop. If you leave the battery disconnected long enough though it will probably need to be reset.
Old Sep 3, 2001 | 11:37 AM
2001TL4KCdude's Avatar
Oracle Apps/Database Dude
It's in your manual. Inside front cover pocket, it comes with a credit card size plastic that will have the serial # and CODE # on it.
Old Sep 3, 2001 | 06:31 PM
Acura3200's Avatar
not true.
If you disconnect the battery, neither the radio or the NAV unit ALWAYS need the code re-entered.
I've had only the radio need it, only the NAV need it and then both need it after disconnecting my battery several times throughout the past 2 years.
Even if you unplug the unit for a year, it will still save all the personal information.
I just received an Acura DVD NAV unit from California that I am currently selling. It was disconnected for about 2 months before I received it. I plugged it in and I saw all the previous owner's information and saved addresses.
Jason
Old Sep 4, 2001 | 03:17 AM
bebber's Avatar
navi antitheft sucks!
So if the navi doesn't always require the code to be entered after the power has been disconnected, then the antitheft feature is pretty much useless. Someone can steal the unit and hook it up and it would work just fine, well 50% of the time.
Old Sep 4, 2001 | 09:18 AM
Acura3200's Avatar
Re: navi antitheft sucks!
Not true either.
Once the cables are disconnected to the NAV unit. You will need the code 100% of the time.
We were only talking about the battery disconnected, not the cables.
Old Sep 4, 2001 | 11:16 AM
daverman's Avatar
Also, if you have a big capacitor somewhere (for an amplifier, for instance), it may store enough energy to keep the Navi alive even after you've disconnected the battery.
Acura3200 is right, once you disconnect the cables, the Navi should require the PIN 100% of the time.
Old Sep 4, 2001 | 05:17 PM
FTM-1's Avatar
Mine asked for the PIN# one time & the baterry or cables were not disconnected. It just asked for the PIN# & I have had the map screen on everytime except twice. this happen over a year ago & has not did it since .
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
eastcoastguy
Oct 29, 2015 03:00 PM
lanechanger
Oct 13, 2015 10:56 AM
MilanoRedDashR
Sep 27, 2015 10:15 PM
Cgannotti
Sep 25, 2015 05:04 PM
