Mysterious Window Movement
Old Nov 3, 2004 | 06:15 PM
jguz's Avatar
7th Gear
It's not that much of a mystery because I figured it out what's going on, but why?
My rear passenger side window will creep down a little when I start the car. It audibly and visibly noticable. I just started and restared about three times and it moved down about 1/2 inch. I just ran out of warranty so I thought I would start here.
I checked the battery and the little status window is green, but it is 3 years old.
Any help is appreciated. I can't be the only one out there.
Thanks.
Old Nov 3, 2004 | 07:51 PM
NSXNEXT's Avatar
Short in the window switch or the motor? I would try this:
1 - Unplug the window switch for the front door (gotta remove the inner door panel) - see if that fixes it
2 - If that doesn't solve it, plug that back in and do the same thing for the rear passenger side window switch.
3 - If all else fails, try swapping the window motor from the rear driver's side
Old Nov 3, 2004 | 07:52 PM
eyesnake02's Avatar
check power and ground connection on the window motor might be loose and that might be the prob.
le^2
Mar 17, 2026 05:06 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
Skirmich
Oct 1, 2015 12:59 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
