Is my tranny gone?
Is my tranny gone?
Today, after about an hour or so of driving on the highway, the tcs and cel lights came on, then the car went as if on neutral and a few seconds later the cel light started blinking. I pulled over and opened the hood and this weird smell came out of it. I pulled the tranny dipstick and it smelled burnt, but the color seemed ok (a bit reddish, not really black). After that, I started the car, put it in all the gears, including reverse, but it wouldn't move. I pulled the codes from my scanner, which were: P1399 (Random/Multiple Cylinder Misfire Detected) and P0740 (Torque Converter Clutch Solenoid Circuit). I had a tow truck take the car to my mechanic's shop, after I told the story to him he said: Tranny's likely gone. What do you think?
I'm probably looking at a tranny rebuild. The question is, since there is no "official" Acura dealership where I live, but there is an official Honda dealership, is our transmission shared with any other Honda product so I can buy the parts needed for the rebuild?
Thanks in advance
Thanks in advance
That's not your tranny. Your tranny failure would be the D4 (since you have a 1999 TL like me) flashing.
By your symptoms above, it seems like your cylinders are miss firing and your either not getting any spark or fuel to the cylinders. And the torque converter lock up could be because your tranny was shifting and was being interrupted because of the misfires.
Honestly, do not go with a rebuilt tranny from Acura as some people are still having failures witht the rebuilt ones. Though, there have been fewer failures.. I would go with a 3G TL tranny.. someone over on the CL side had successfully put in a 07-08 TL tranny into his CL. It bolts directly in with no fitment issues but you will need to do a few things..
Here's the thread:
https://acurazine.com/forums/2g-cl-problems-fixes-70/another-solution-my-auto-cl-guys-758220/
Here's the thread:
depending on trans model there are 2 solenoids in block on top side of trans attached with 3 10mm bolts.the transmission cooling lines also mount here. remove the bolts and the solenoids being careful not to break the rubber molded seal that fits the solenoid block itself. underneath you will find 2 screens if these screens are full of a brownish material it is converter clutch material.cleaning the screens and reassembling may prolong the life of the trans somewhat but it is a sure sign that the torque converter clutch <lock up> is beginning to degrade and fall apart. unfortunately a filter change requires removal and transmission dis assemblybut if the code persists a trans overhaul and new converter are pretty much the only answer to your problem.
Well you beat me to it dude! lol I did some research and was looking around on the code and came up with the above solution but like that solution says more than likely he needs a new transmission.
seems like he or the previous owner was not taking care of the proper tranny fluid changes.
B A N N E D
^ take your solenoids out, clean them drain the fluid and see if it helps. 99s are FAR less prone to issues than the 00+
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
p740 is the code I got when my tranny took a dump the 3rd and 4th time i got THAT code!
Do as fstyms1 says- he has actually rebuilt a few of these trans and the 99 has far less issues than later years
It may be a simple problem
not the same- not drop in or everyone would be doing it-
the regular honda trans seem more reliable than Acura...or there are more hondas so it seems like fewer problems
B A N N E D
let alone being a couple of hundard pounds lighter then our acura's
also he is talking about a 99, so only a 4-speed, and not the shitty 5-speed
They say almost the same thing about our transmissions...
http://autos.msn.com/research/vip/re...Acura&model=TL
That's why I thought they might be the same...
you can try. The mere fact you have gone this long with that code is beyond me. The 2 times i had that code i had about half a day
B A N N E D
and for JterrorC saying he has already tried resetting the light, and it coming right back on after going into 5th gear, kinda diminishes only hope that his tranny might still be saveable, but only way to actually tell, is to do as recommended
Always a Honda =Þ
https://acurazine.com/forums/showthr...ighlight=p0740
this is the post when i was asking for help....(mind you i like tools...but kinda lost when workin with somthing i havent touched...)
anyways...the code came up in spring for sure...did som search but only came up with ppls tranny gon to shyts...MINE HASNT....woo hoo...mayb im the exception...lets hope...tranny only has 40k..
"JUAN" wanna work on this???...you sent me all that info on the original post...but u lost me with the first pic....pm me kid..
you want to work on what fstty is saying?...
Pham Alvan
03-16-2016 09:17 AM
lanechanger
10-13-2015 10:56 AM
