my ongoing a/c trouble...
Old Jun 29, 2010 | 10:01 PM
  #41
hANDYcaptd's Avatar
It's the Halladay season!
He's doings teh swappppp!
Old Jun 30, 2010 | 07:06 AM
  #42
assclown's Avatar
2000 acura tl FPR
^^that's what he said. i figured why buy a non type s when i won't be using it long, and just see if i can have this ECU to hold me out before i do swap.
Old Jun 30, 2010 | 01:04 PM
  #43
friesm2000's Avatar
B A N N E D
Originally Posted by assclown
so uh... i received my ecu yesterday and sent it off to richiev6 to have a key programmed to it, i was just curious since this ecu is a type s, and my car is not a type s, would it be ok to plug the new ecu in with my current setup (i'm sure i'd get a CEL, but honestly i don't care, we don't have inspections here) but would that possibly damage something? it's getting rough here without A/C
possibly, cause aren't the pinouts out ever so slightly different (btw is it an auto S ecu, since i don't think you have actually done it yet), let alone also being different between the years slightly too
first thing i would say is CHECK the PINOUTS (you don't want something shorting out, just for being lazy; "opens" [like having no wiring for the runner control] should be no problem though [except for maybe a ground or something, so make sure those are fully intact first])
Old Jun 30, 2010 | 02:06 PM
  #44
assclown's Avatar
2000 acura tl FPR
yes it's an AUTO type S ECU. i figured i'd probably get a check engine light maybe for IMRC and it might not like that i don't have VSA. I thought the ECUs were all the same pins?? I'd just like to enjoy some a/c before i do this swap.
Old Jun 30, 2010 | 03:13 PM
  #45
friesm2000's Avatar
B A N N E D
only thing with that vsa, tranny/engine might go into limp mode, idk, but it won't hurt it though, just does not run the best and suck that gas down in the process
as far as pinouts, they might have changed some of them though, because of adding the runner control and the VSA, so you might have to repin the connector in order for it to work properly (and not fry anything)
Old Jul 21, 2010 | 06:29 PM
  #46
assclown's Avatar
2000 acura tl FPR
so i had the interior apart today because i was installing the isimple soundbyte adapter (i just bought an ipod touch) and i figured, hmmmm. i got the ecu back from richie, so why not try things out. i was feeling dangerous, so i pulled back the carpet and removed my ecu, looked at the two and they looked EXACTLY the same, minus the part numbers of course. so i said what the hell plugged in the new one. she started up just fine, the a/c works!!! the only problem i see is TCS light is on now, but who the hell cares about that?
Old Jul 21, 2010 | 09:22 PM
  #47
totaledTL's Avatar
You might, if you need traction control....
Old Jul 21, 2010 | 09:48 PM
  #48
assclown's Avatar
2000 acura tl FPR
come on man. how much tcs do we really need in ky?
i'll be losing it anyway after the swap
Old Jul 22, 2010 | 11:01 AM
  #49
totaledTL's Avatar
Haha, maybe when trying to get on 65 from Waterson Xpressway-
Old Jul 22, 2010 | 11:03 AM
  #50
assclown's Avatar
2000 acura tl FPR
you should know as well as i know tcs only engages ~<20mph's
the stock ECU is going back in for baseline dyno on saturday, i don't want the higher redline in the type s ecu to blow out my engine!
Old Jul 22, 2010 | 11:15 AM
  #51
totaledTL's Avatar
No- didn't know that. Mine is VSA-
Where did you see that info?
Old Jul 22, 2010 | 11:28 AM
  #52
assclown's Avatar
2000 acura tl FPR
i know it's in the owners manual, (i don't happen to have a copy of that at this moment) i need to install adobe acrobat so i can open up the service manual, i'm sure it's in there too.
fsttyms1 will vouch for me though.
Old Jul 22, 2010 | 11:30 AM
  #53
totaledTL's Avatar
I just found it- 18 mph.
I don't see that same info for VSA tho. Thanks.
Old Jul 22, 2010 | 01:02 PM
  #54
assclown's Avatar
2000 acura tl FPR
i think VSA is an always on thing. i could be wrong. i only have a 2000 so i know nothing about VSA
Biggie_B
May 27, 2025 05:51 PM
jdm_94-07TypeS
Oct 7, 2015 11:14 PM
hashbrown
Sep 29, 2015 12:13 PM
lovic87
Sep 15, 2015 06:07 PM
dlknight
Sep 3, 2015 07:54 PM
