My car has been 'pooned...
Spoon 1.35 bar radiator cap
Spoon T-stat
Spoon T-switch
I asked my friend's shop about the Mugen parts, but it turns out that I can spend 20 bucks more (normally these Spoon parts would cost over 200 bucks, but I got it without tax or shipping, and a small discount since they are not big-profit parts) and get Spoon parts with higher bar cap and T-stat opens at 63 degrees C.
Relatively easy installation, although coolant went EVERYWHERE (but got 2 gallons of coolant for free from my buddy who works at the Honda dealership ).
That is all. I just wanted to brag.
EDIT --
P.S. During installation, I noticed that Suburban Acura didn't put in the oil jet kit per the recall when they installed the new transmission.
Spoon T-stat
Spoon T-switch
EDIT --
checkmate...
Nice. I gotta ask, how does she run with all those goods on the track? Is it a decent improvement over stock (seeing that we weigh 3400 lbs)?
I had a couple of seasoned drivers test out my car on the track and they said it rotates pretty well and surprisingly does not understeer much.
Cool,
and the new trannies have the oil jet built in
Originally Posted by fsttyms1
Cool,
demolition x -- Around 85-90 bucks each. They are more expensive than the Mugen parts. I figured I would try Spoon since nobody else has, and they open up at a lower temperature.
Resident Troll.
1 Post
congrats on the new mods!!! did you notice any different in the way the car felt? I would imagine that with a cooler motor you should have found a few extra hp.
You think this could cause any problems in the winter?!?
Could've been my imagination, but during the 2->3 shift, the car buckled... it usually upshifts and just goes, and it feels like it's picking up speed faster in the mid-range. Regardless of whether it adds power or not, I was all smiles.
In the winter, I don't foresee any problems, except maybe the heater won't blow as hot. Speaking of which, I better reconnect the coolant feeds to the TBs.
Resident Troll.
1 Post
Originally Posted by Pure Adrenaline
Thanks.
Im assuming that spook doesnt make these specificaly for our cars so which application will work for us?!?
I was just going to ask you if you had reconnected the coolant feeds!!!
Thermo stat -- 19301-BB1-000
Radiator cap -- A11-19045-000
They can be found on www.optionsauto.com.
By the way, I meant to say that the t-stat starts opening at 65, not 63; fully opened at 70.
Wifes Car
Originally Posted by shockwave
Are you sure that 70C is not two low? I've heard that some ECU's will never go into closed loop mode with a thermostat that is two low, because they never see the engine as fully warmed up. 70C is only 158F, which sounds pretty low. I would try to find out if the TL ECU will go into closed loop mode at this temp.
the main down side is the car runs alot richer so watch your gas mileage
