My "BRAKE LAMP" Light is on...
Old Apr 23, 2007 | 06:17 PM
myTaLizaS3.2's Avatar
What does that mean when your Brake Lamp light is on? I checked on the brake lights, but they all work fine. Anybody know what's wrong?
Old Apr 23, 2007 | 06:44 PM
69tl's Avatar
mine happen the same thing what i did was just turn off the engine and restarted again then the light go away.
Old Apr 23, 2007 | 06:52 PM
JPTL-S's Avatar
アキュラ 力
This means that one or several of your brake lights is burned out. Note that some of the bulbs have a dual filament and so it may appear to work when the lights are turned on but the second filament may not light up when the brake pedal is depressed. Therefore you might want to have someone check the lights while you step on the brake pedal if you have not tried this yet.
Old Apr 23, 2007 | 07:17 PM
yeah, that was already checked. all of them work fine. when the lights are on, it's all lit. when lights are on and stepping on brakes, they are all light. no problem at all. I turned off the engine, and it still came back on.
Old Apr 23, 2007 | 07:21 PM
JPTL-S's Avatar
アキュラ 力
Just out of curiosity, is the center brakelight also working when you do this perform your check?
Old Apr 23, 2007 | 07:22 PM
yes
Old Apr 23, 2007 | 07:32 PM
dreem1er's Avatar
deal with it
are both the lights in both the tails on......theres two bulbs per light......and sometimes a bulb will be fine til it warms up then it burns out but then it comes back on after it cools again......
Old Apr 23, 2007 | 07:35 PM
fsttyms1's Avatar
I agree. Check check and double check. One of them has to be bad. MAybe pull them out and check them 1 by one just to make sure
Old Apr 23, 2007 | 09:11 PM
BAPE head's Avatar
I have this problem too but i have the JDM Inspire Tails, i have checked and rechecked and changed the bulbs but the Brake Light on the dash never turns off.
I just learned to live with it.
Old Apr 23, 2007 | 09:17 PM
01tl4tl's Avatar
Have you checked the level of the brake fluid yet?
That should set off the sensor too
Old Apr 23, 2007 | 09:50 PM
L3wD's Avatar
FPR pimpin'
also did you use any LED bulbs? that will also set off the light
Old Apr 23, 2007 | 10:03 PM
ok, i checked again, and yes, one of the bulbs are messed up. i guess it's best to check when it's dark. thanks guys.
Old Apr 23, 2007 | 10:15 PM
dreem1er's Avatar
deal with it
that would be the "BRAKE" not a "BRAKE LAMP" indicator........
Old Apr 24, 2007 | 02:14 AM
01tl4tl's Avatar
AHHHH I see dreem1er
As I have full fresh brake fluid and when I saw one taillight bulb was out while setting the alarm, I replaced all the bulbs so there would be no surprises
Therefore- I do not know what any of the warning lights look like-except low fuel!
Sorry if I mis-informed anyone
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Ny1718
Sep 11, 2015 09:21 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
