My 99 Chrome Shift Plate
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
I finally did my 99 shift plate. It turned out perfect!!!!! It took all of 10 minutes to do. Im telling you guys this is an easy mod for almost no money if you have a 99 and have paint thinner. I want to thank NSXNEXT for his example. He inspired me to do this .
Has anyone had their shiftplate like this for a prolonged period of time...Does it seem to scrath easily? This looks like a nice mod, but I am concerned that it worked become scratched too easily.
Originally posted by Mstyle
How do you do that..Just use paint thinner?? Is that safe...Does anyone know how to take apart the shift plate...
Its real simple. All you have to do is pop off the plastic around the shift plate . You will have to unscrew your shift knob and just pop off the shift plate . Just a little pressure and it will pop off. I just used the paint thinner outside . I let it sit for 10 minutes or so and the mostly all of the outer layer came off with hot water. Nice and chromey
Originally posted by acnup00tl
Its real simple. All you have to do is pop off the plastic around the shift plate . You will have to unscrew your shift knob and just pop off the shift plate . Just a little pressure and it will pop off. I just used the paint thinner outside . I let it sit for 10 minutes or so and the mostly all of the outer layer came off with hot water. Nice and chromey![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Let me get this straight..Just screw off the Shift Knob and then pop off the shift plate...Do you need to pop off tabs or something..When I was looking at it, it didn't seem that easy..Sorry for all the questions..Thanks for the help....
It really is easy unscrew your shift knob first Then pop off the plastic around the shift plate . Once tha is compleate you can just pop off the shift plate. Once you get the plastic around the shift plate off it should look like this
i did it too!
:smokin: thanks to nsxnext excellent idea ! still don't know how he dicovered that? but i ended up using the finger nail method he did. ya know that shift plat pops off in 3 seconds without removing the black shifter housing. unless you had it off for other reason? kman
one more
one more
Originally posted by whitediamondnav
Can we just buy a '99 plate and do this, and put it on our '00 model? If so, any idea how much one costs?
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
Received 1,080 Likes
Originally posted by evsweat1
After you use the paint thinner to strip it. What do you use to make it chrome. Is there a chrome paint or the chrome is right under the stock finish???
Shogun Assassin
Originally posted by BLaCk Acc
Can someone post some instructions??? i wanna do this, but i dont wanna screw up and break the plate or do somethin stupid,, thanks
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
SidhuSaaB
05-30-2020 12:40 AM
